Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th April 2010, 12:08 AM   #1
Default Shorten leads of primaries to connect them in series ?
Hi All,
I have a somehow "stupid" question.
I need to connect the dual 115V primaries of my toroid in series as we have 230 V around here.
So far so good, both primaries are clearly identified. As the toroid is quite big, the leads are almost 20 cm long... hence my question.
Should I shorten the 2 (End of 1st, Beginning of 2nd primary winding) leads before connecting to each other ?
And, I feel silly asking, but want to be sure: Is there an "order" to respect in connecting the primaries, or is everything fine as long as IN/OUT-IN/OUT is respected ?
Thanks in advance for your help
Max
Old 7th April 2010, 03:45 AM   #2
tinitus is online now tinitus  Europe
Maybe this helps http://www.amplimo.nl/download/770xx.pdf
No real need to shorten them, or you need to take care in removing the lacquer
Put them together
Wind some solid core copper wire around the ends, tightly
And solder
One piece of 50mm heat shrink tube, half way on
Shrink, bent it back loosely
Mount another piece of tube
Well, thats one possible way
Old 7th April 2010, 04:54 AM   #3
There is most certainly an order. The windings need to be in phase.
As for shortening the leads, it's perfectly permissible but you are painting yourself into a corner should you ever want to connect them differently.
Old 7th April 2010, 02:48 PM   #4
Default Thanks for input... any cons in doing like hereunder ?
Thanks both for your input, I will tap them together in a binding post, most probably soldered together before as mentionned by tinitus.
Any reasons not to do so ?
Should look like in the pic, the clamp will be another but I had this one around for taking the pic (primaries in series on the left, mains on the right))
Max
Steel Leads and Tinned Copper Leads impsick Parts 0 19th April 2009 10:01 AM
is it safe to connect these secondaries in series? jarthel Tubes / Valves 3 15th June 2007 12:28 PM
NS LM478x series chips with pins that say "no connect". captain Chip Amps 4 8th November 2004 06:23 AM
How to cut/shorten long heatsinks Jan Dupont Everything Else 15 27th May 2004 06:31 PM
help connecting primaries Raj1 Parts 12 23rd September 2003 04:59 PM
Page generated in 0.08595 seconds (69.65% PHP - 30.35% MySQL) with 11 queries
