Go Back   Home > Forums > Amplifiers > Power Supplies
Old 6th April 2010, 06:40 PM   #1
Default meanwell ???
I have a 27v meanwell power supply that Quit working. I know just enough to be dangerous . One of the 4 transistors attached to heatsink/case gets hot rapidly when I plug the PS in. It is labeled
F
c3320
JT52
Looking for a replacement I can find sc3320 and nte2311
Is the one heating up bad or the one that stay's cool ? or is there something wrong before in the circuit that causes it to heat up rapidly. It would cost more to have fixed than a replacement but If I can solder 3 points on a 5$ replacement part that would be worth it.
Old 6th April 2010, 07:12 PM   #2
event horizon's Avatar
The transistor is likely to be a 2SC3320. Unfortunately i can't really help you as i have absolutely no idea of the type of circuit that SMPS employs. Normally to find faults i'd power up the SMPS chip only using a 12V or 15V regulated power supply to see what's going on. This would involve knowing what SMPS chip is used in the design itself & i have no idea tbh.
So although i meanwell (couldn't resist it ) i'm about as useless as a chocolate teapot..
Perhaps if you take a look inside & let us know what PWM regulator chip is employed we can help a tad more
"Never let your morals prevent you from doing what is right!" Salvor Hardin
SMPS Meanwell S-250-24 (24V-10A) [20€+ship] madqwerty Swap Meet 1 19th September 2009 10:25 AM
using meanwell SMPS S-350 as power amp PSU? lhgin Power Supplies 2 18th August 2009 10:36 AM
FS: Assembled 41Hz Amp9 Class D-amp and 15volt Meanwell SMPS nic6paul Swap Meet 1 8th June 2009 11:20 PM
Page generated in 0.07593 seconds (63.30% PHP - 36.70% MySQL) with 10 queries
