What fuses to use
What fuses to use
Old 6th April 2010, 06:50 PM   #1
Andy5112405 is offline Andy5112405  United Kingdom
Banned
Default What fuses to use
I am building a 80Watt / Channel Class A Amplifier based roughly on a Mark Levinson design.
The PSU uses 2 x 500VA Toroidal transformers ( 4 x 45V secondarys) feeding bridge rectifiers then nearly 0.5F (yes 1/2 a Farad) of capacitors each. So each secondary has a capacitive load of about 0.5F.
The transformers are rated at 5.1A per secondary.
So far every fuse that I have tried has blown (10A Time Lag) and (5A Anti Surge). The fuses are in the secondary supplies to the bridge rectifiers. The rectifiers are rated at 35A and neither the transformers nor the regulators have come to grief.
What size, and what type, fuses would you recommend?
The amplifiers are expected to pull about 4A at full output.
Intuition states that I should use 4 x 1.3 = 5A Anti-Surge but these can't survive the inrush current of the huge capacitors.
Andy
Old 8th April 2010, 05:45 AM   #2
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
With that much capacitance,I'd think it's time to consider a soft-start circuit!
What fuses to useHide this!Advertise here!
Fuses rtarbell Parts 7 8th November 2005 04:14 PM
question on fuses Antonix Solid State 8 13th October 2005 03:52 PM
Why are these fuses blowing Darin P-B Solid State 41 30th May 2005 11:56 PM
blowing fuses homegrown45167 Car Audio 2 22nd October 2004 01:16 PM
Copyright ©1999-2017 diyAudio
