Piling two toroidal transformers
Old 6th April 2010, 12:33 PM   #1
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Default Piling two toroidal transformers
Hello guys,
I am going to build a Gainclone amplifier, and I am going dual mono inside the same case. The question comes to how to alocate the trafos.
Is there any drawback in mounting one above the other using a single bolt? I've seen doing it, but I dont know if they will interact with each other.
Doing that, there is enough clearance to fit a 3rd trafo for supplying another pair of Gainclones, making it a 4-channel amp.
Thanks,
Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 6th April 2010, 12:36 PM   #2
regiregi22's Avatar
I forgot to say that, being a 3U chassis (12cm height), it is possible to put a 4cm piece of something between them, making a sandwich. Maybe rubber or something i can find. They will share the same long bolt.
Thanks for all,
Regi
Old 6th April 2010, 12:41 PM   #3
audi0 is offline audi0  Australia
Take a look at this post from yesterday, it might answer your question Dual Toroids in Close Proximity...An Issue?
Old 6th April 2010, 03:59 PM   #4
regiregi22's Avatar
Thanks for your response. I have been researching the web and seems to be feasible to stack them, but better to separate them as much as you can, using spacers between them.
But I still want to hear any other experiences or theorical explanations
Old 6th April 2010, 04:35 PM   #5
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Piling two toroidal transformers
if they vibrate at all on their own they will vibrate like hell on top of each other. Usual practice with stacked transformers is to pot the bottom with a long bolt and mount the top one compliantly.
Paradise Pre-reg PSU PCBs
Piling two toroidal transformersHide this!Advertise here!
Are toroidal transformers best? walker Solid State 43 15th September 2006 03:21 PM
Piling up parts for an Aleph...5? Fuling Pass Labs 12 18th June 2004 09:44 PM
Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) Rixsta Pass Labs 10 23rd April 2004 04:41 AM
toroidal transformers nbcd Parts 2 2nd May 2003 09:36 PM
