How do I know what a transformers VA is?
Old 5th April 2010, 03:39 AM   #11
Rembrant is offline Rembrant  United States
LOL, 20LBs? Surely you are joking. I have whole gain clones that don't weigh that much. If it really is 20Lbs then you could probably power about 5 of those amps. You might want to save it for a Home Theater project. It's great for testing too. It will be quite hard for the normal GC to drag the voltage down on that one.
Honestly, I would try to find a 150-200VA transformer in salvage or otherwise and use that for the permanent install. Seems like a waste otherwise. At least you have room to grow.
Old 5th April 2010, 07:37 AM   #12
Elvee is offline Elvee  Belgium
Elvee's Avatar
Have a look at this thread:
Trafo with unknown power rating
Old 6th April 2010, 12:11 AM   #13
caxxxxxx is offline caxxxxxx  United States
Yes, you are right. I weighed myself today without the transformer in hand, weighed 174 lbs. Then I grabbed the transformer and reweighed myself - 190 lbs. So it weighs 16 lbs, don't know where I got 20 lbs from.
Funny you mention, but I am actually planning a home theater project. But my point wasn't really whether or not it was enough for a gainclone, I was wondering if there was any reliable method to figure the max avg. available power of the trafo, since I have 2 other ones that I need to measure as well. Looks like from reading the other posts here that it is mostly guesswork, kinda bummer. Here's a pic of mine from the ebay auction
Old 6th April 2010, 04:59 AM   #14
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
if you are using that traffo to power up you gainclones you have nothing to worry about, you have it on hand, use it....that's good for a t least 5 gainclones, maybe more...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 6th April 2010, 06:53 PM   #15
Andy5112405 is offline Andy5112405  United Kingdom
Banned
As everyone is saying. The best bet is to measure the iron core and compare it with others at Farnell or RS Components. Transformers come in standard sizes so you should find it fairly easy to compare its dimensions with known values.
Old 7th April 2010, 10:57 AM   #16
Originally Posted by caxxxxxx View Post
... is about 3.75 Inches tall and 5.75 inches in diameter, and is a toroid. ............. it weighs 16 lbs,
this is very tall relative to diameter toroid not normal toroid.
It is a special not a standard.
I suspect it is well over 1kVA, which usually weigh 6.5kg to 7kg (14.7lbs to 15.4lbs) possibly 1.2kVA to 1.5kVA.
regards Andrew T.
Old 7th April 2010, 11:29 AM   #17
Banned
Just looking at the Farnell site should give you a good idea when comparing it with other known transformers. A 1000VA transformer would need to be approx 167mm x 71mm and would weigh around 7.5Kg. I would estimate that yours is somewhere around 800VA.
Old 8th April 2010, 02:10 AM   #18
Wow, so this would be the only trafo I would need for a Home Theater project? Thats actually what I was jokingly thinking to myself when I first grabbed and almost dropped it from the UPS guy, lol. Looks like I may have been right.
What should I look for if I decide to power up 5 or more gainclones from this? Heat, power spikes, common sense (smoke is probably not a good thing right......???...)
Old 8th April 2010, 10:43 AM   #19
extreme difficulties in sorting the grounding to achieve low to zero hum and similarly buzzes which both become audible at the speakers.
regards Andrew T.
How do I know what a transformers VA is?Hide this!Advertise here!
Transformer VA versus output power VA nigelwright7557 Solid State 8 18th May 2008 03:57 PM
2000 VA toroidal transformers GeeVee Swap Meet 0 9th August 2007 02:47 PM
W.T.B. - 2 Toroid transformers 2x42V 1500 VA AR2 Swap Meet 1 6th July 2005 01:08 PM
determine VA of unlabeled transformers matt20102 Chip Amps 3 22nd March 2005 02:12 PM
Pair of 625 VA Transformers - 2 * 42v @ 7.44A Jason Hubbard Swap Meet 1 7th March 2003 09:51 PM
Copyright ©1999-2017 diyAudio
