I have a transformer like the one pictured, but there is a thin sheet of copper where the brown paper is in the one pictured, would this copper carry any voltage? it is out of a old pioneer integrated amp.
#2 |
It is probably a gauss band.
Quite rare among cheap EI transformers. Very rare inside cheap commercial gear and not seen much in expensive gear. The copper band should be outside the EI frame, not through the EI window. If it went through the wiring window it would try to be a shorted turn. Use it if you have the correct VA and Vac.
regards Andrew T. |
| Simple SE power transfomer question? | ryc989 | Tubelab | 29 | 3rd May 2010 07:29 PM |
| What to do with a 5k output transfomer? | Switch | Tubes / Valves | 17 | 23rd July 2008 08:12 PM |
| transfomer for monitor - 602M | jfrago | Vendor's Bazaar | 0 | 3rd August 2007 04:53 AM |
| Input transfomer on P3A | jesper | Solid State | 9 | 30th October 2004 07:39 PM |
| Think this is worth $60? (transfomer) | Hybrid fourdoor | Swap Meet | 5 | 22nd June 2004 10:56 AM |
| Page generated in 0.07985 seconds (66.04% PHP - 33.96% MySQL) with 11 queries |
