A-class Preamp PSU
A-class Preamp PSU
Old 15th October 2013, 03:52 PM   #71
maouna is offline maouna  Greece
what are the benefits of using a shunt regulated psu in a preamplifier, over a series regulated one? Are there any improvements in sound?
my psu for preamp is based on lm317/lm337 regulators and im thinking of building the A-class Preamp PSU posted here by APEX.
Old 15th October 2013, 04:35 PM   #72
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
I'd say that the main benefit is that a shunt regulator can isolate A.C. load current to a localized loop area. In other words, it can minimize the A.C. current interaction between various circuit blocks which might stem from any shared primary power supply connections. This also applies to the A.C. current demanded from the power supply elements prior to the shunt regulator, making the ecurrent demand D.C.
Old 15th October 2013, 05:16 PM   #73
Mr Mile do you have PCB for these preamplifiers?
Old 15th October 2013, 05:21 PM   #74
ok. i understand.thanks for answering.
Old 15th October 2013, 10:58 PM   #75
mihailo is offline mihailo  Serbia
My version. Not tested.
Look if there are Errors, so I can revise PCB.
Old 28th October 2013, 08:41 PM   #76
Mr Mile,i want a 30V single rail PSU for a preamp so i made a new board based on your class A 2x24V PSU schematic but using the upper positive half.i also added a fuse on the board. do any part values have to be changed for 30V output? on a earlier post you stated that BF245 could be substituted with BF244, 2N3819, 2N3823. does it apply also to this class A PSU?
Old 15th December 2013, 02:45 PM   #77
desertstorm is offline desertstorm  Philippines
Send a message via Yahoo to desertstorm
Default apex psu
Sir apex any replacement for BF245 /BD242/BD241 this items not available here in my place pls.help. thanks and regards..merry Christmas sir apex..
Old 15th December 2013, 04:00 PM   #78
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Use 2SK246 and TIP31/TIP32
Old 16th December 2013, 06:04 PM   #79
thank you so much sir apex for your quick reply...regards and more power sir..
Old 16th December 2013, 06:39 PM   #80
Default APEX tone Control and X -over projects..
Sir Apex here is my on going projects...thanks and regards.
A-class Preamp PSUHide this!Advertise here!
PSU of class A amps GKU Solid State 12 16th September 2006 07:54 PM
Regulated PSU for Class D? bambadoo Class D 6 9th February 2006 12:17 PM
Class A amp all over :) Need PSU! Semir Solid State 19 27th December 2004 02:04 PM
class A amp with switchmode psu??? demons_wing Class D 2 17th June 2004 10:52 AM
New PSU for class A amp nikosgr Solid State 3 10th February 2003 09:14 AM
