A-class Preamp PSU
A-class Preamp PSU
Old 1st April 2014, 12:27 PM   #101
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Originally Posted by andresolomko View Post
On output I have only 13V of vdc with load
and (36!) with no load, so there is a huge voltage drop.
Hi, are you saying that you have 13V DC on the output when a load is connected and 36V DC when no load is connected ?
It's only audio. Member of the non modular PCB design committee
Old 1st April 2014, 12:30 PM   #102
andresolomko is offline andresolomko  Finland
Exactly. I suspect a BD640, since there is a strange voltage reading. 36 vdc on C and almost 0 on BE. If anyone sucseeded with circuit I need a reference voltages
Old 1st April 2014, 12:52 PM   #103
R.I.P.
post your schematic, preferably with some test measurements appended.
regards Andrew T.
Old 1st April 2014, 02:01 PM   #104
Default schematics
I am not sure how to do it but there is pdf All confusing measurments are with checkmarks
Old 1st April 2014, 03:00 PM   #105
R.I.P.
Check voltage across the three diodes and across the two 1uF caps.
Check the Vbe of the 4 output devices.
regards Andrew T.
Old 1st April 2014, 08:52 PM   #106
Voltages on diodes are the same as supply (36vdc)
On fets are 12v
Same as output
I will test more but my main question: can this class A PSU work in a single-rail mode:
ie can I use only upper part of circuit? If it is so, so I have to debug it. Can be some problem on PCB or some faulty component.
If I feed it from unipolar bridge DC rectifier?
Old 1st April 2014, 11:05 PM   #107
Ok, my question is answered It was a bad 640 (strange, but it happens)
It can. Feeding from a ready made rectifier (+ to plus rail, - to ground) I can adjust voltage from 36 to 26,2vdc.
It's not a problem for me, since I use it for a mic pre. And extra 2v of headroom just make it beefy. So device with the same components values can regulate within 10v,as it was stated. Haven't noticed any heating problems so far, but ime will tell
And yes. Sound is much "tighter", comparing to LM*** -based PSU
Old 5th April 2014, 07:20 PM   #108
Default Help, please!
Pls anyone help!!!! It worked 1 day, suddenly R22 gave a smoke.
Also BC640. Replaced, the same story. Under load it gives like a half of supply voltage.
Voltages on 1u similar.
Trimmer don't help much. All problem is around BC640. I replaced few and all give a different result
Only one of 3 worked properly for a while before death.
Under normal working conditions collector of BC640 should give a half of output voltage.
i. e. when it was working normally I had about 12v on it and 25 on output, regarless of load.
As soon as I have a load it shows all weird things
Why the same place all the time? Anyone who is more experienced, tell me where to olook.
I am using MJE29/3050 since I can't get BD241/2 They are not direct replacement, but should work.
Can it be a reason.
Instead BC556 I am using 557, and BC549c instead of 50
Old 28th February 2015, 04:25 AM   #109
rb elec is offline rb elec  India
Default help
Originally Posted by maouna View Post
Mr Mile do you have PCB for these preamplifiers?
hello sir Mile
May I use this preamp with your h900amp
as i have completed one but not getting
suitable preamp with decent gain
please help
Im waiting
Old 28th February 2015, 09:11 AM   #110
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by rb elec View Post
hello sir Mile
please help
Im waiting
Use ML3 preamp from thread: http://www.diyaudio.com/forums/analo...reamps-50.html
A-class Preamp PSUHide this!Advertise here!
PSU of class A amps GKU Solid State 12 16th September 2006 07:54 PM
Regulated PSU for Class D? bambadoo Class D 6 9th February 2006 12:17 PM
Class A amp all over :) Need PSU! Semir Solid State 19 27th December 2004 02:04 PM
class A amp with switchmode psu??? demons_wing Class D 2 17th June 2004 10:52 AM
New PSU for class A amp nikosgr Solid State 3 10th February 2003 09:14 AM
