Go Back   Home > Forums > Amplifiers > Power Supplies
Old 31st March 2010, 06:18 PM   #1
awedio is offline awedio  United States
awedio's Avatar
Default 7W dissipation in linear reg.= 100degC???
Hi. I have an LT1084 12V/5A linear regulator dropping about 3V and passing 2.2A that is heatsinked nicely to one of these:
http://media.digikey.com/photos/Aavi...1102B02500.jpg
1.75" tall and rated at 10W/50degC rise
I have measured up to 98degC at the heatsink... dangerously close it would seem to the 105C rating of the TO-220 package. Should I be worried or looking at a bigger heatsink?
"Where is my mind? Where is my mind? Wheeere is myyy mind? Waaay out, in the water, see it swimmin'..." Black Francis
Old 31st March 2010, 07:22 PM   #2
Bill_P is offline Bill_P  United States
On the Aavid Thermalloy web site 531102B02500G is listed as 10.4 C/W, so you should expect a 73C rise at 7 Watts dissipation. With a room temperature of 25C, you should measure 98C at the heatsink so your results are consistent. Based on the thermal considerations section of the LT1084 datasheet, that puts the junction of the power transistor in the IC at about 117C which really is too hot. It is probably a few degrees higher than that since the thermal resistance of the case to heatsink interface is not zero. I would suggest a bigger heatsink.
Old 31st March 2010, 07:38 PM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
It's rated to 150C (at which point thermal protection should take over, so don't worry too much about exploding it), so it's perfectly okay.
I'd put a bigger heatsink on it, just so I don't burn myself while poking around!
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 31st March 2010, 08:01 PM   #4
awedio's Avatar
Thanks, guys.
That picture was of a slightly smaller heatsink, the one I am using is rated at 10C/W but hey that's pretty much the same. Bigger heatsink it will have to be, and I should have done the simple calcs first. I just thought that the ratings were "worst case" and I did not expect quite so much heat. Now I have to redesign the pcb to make room for a bigger footprint, I have limited vertical space.
Old 31st March 2010, 08:31 PM   #5
I'd also recommend a larger heatsink; the reliability of the regulator improves a lot when you use a somewhat larger heatsink than necessary to remain just below the maximum temperature rating.
Old 31st March 2010, 08:46 PM   #6
Tim
It isn't perfectly ok to run anywhere near 150C if you want reliability. Rule of thumb is that failure rate doubles for each 10C increase in temperature. You would have to request a full reliability report for the LT1084 from Linear Tech to see what the projected life time is at 150C. From there back the temperature down as needed to get the component lifetime needed for the application. Conservatively I try to keep junction temps below 100C at the maximum room temperature expected.
Old 31st March 2010, 08:58 PM   #7
Electrons are yellow and more is better!
peranders's Avatar
awedio, curious what are you feeding 2.2A? Strive to 70-80 degrees C tops, that's my advice.
/Per-Anders (my first name) or P-A as my friends call me
Old 31st March 2010, 09:40 PM   #8
nigelwright7557's Avatar
A bit of heat isnt too much of a problem.
I have seen MOSFETs that will run upto 175C.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 31st March 2010, 09:48 PM   #9
peranders's Avatar
Do you speak by experience here? This is not a good design practice.
Old 31st March 2010, 09:51 PM   #10
As I say a bit of heat is OK.
All you have to do is look at some of the cheap amps on the market with high watts and small heatsinks. They seem to get away with it.
If you dont mind paying a small fortune for a heatsink and fans then you can run at 30C all day.
7W HLLY MK-II Mini Vacuum Tube Amplifier New Product hllyelec Vendor's Bazaar 3 12th July 2009 12:36 PM
7w dual emitter resistors? JJGross Parts 3 1st July 2008 04:37 AM
Swap 2SA991 sk389bl 7W 220R dhole Swap Meet 0 25th April 2008 11:10 AM
7W enough for 90dB speakers? kacernator Tubes / Valves 26 21st January 2008 04:48 PM
mosfet dissipation bogdan_borko Solid State 15 10th June 2006 08:55 PM
Page generated in 0.10488 seconds (82.56% PHP - 17.44% MySQL) with 10 queries
