Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th March 2010, 10:33 PM   #1
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
Default help with disigning 3 phase AC to DC converter
specs:
input - 3 phase AC magneto (no nutral), voltage output depends on freq , and goes between 0 to 150V
requered output :13-14.7V DC , dead time is not important , but i want it to be a full bridge for higher efficiency .
my idea is to use 6 switches , with some control circuitry that will turn on the right switches when the load voltage is between 13-14.7V
the basic diagram can be seen in pic (which i found googling) , but i dont see the purpose of the 6 diodes , as they turn the circuit into regular full bridge 3 phase rectifier , without any control of the output voltage.
i'm thinking of using power mosfets , and want to know if there are any control ics for this type of circuit.
any help would be apriciated
if you are not living on the edge you are taking too much space
Old 30th March 2010, 02:49 PM   #2
indianajo's Avatar
Default 3 phase to DC converter
If you buy a dead 3 phase motor drive, the input circuitry will already be in it. Six diode units for rectifying 460 AC to 400V DC (or 200 on 230 3 phase) are a packaged assembly from the manufacturers. Such units also contain boards of valuable 400VDC 3000 uf capacitors in parallel. Many times this part of the circuit is okay. If you use 6 diodes instead of 2, the unit stays powered up if a phase drops out and issues an error code to identify the bad phase. The outputs of these drives get shorted frequently around food factories, where the washdown crew kills them with their hose. Try making the aquaintance of a maintenance man in a factory, to buy his discards, or post an ad on the electronics section of a classified service- $25 or E20 for a dead drive should be about right.
The output waveform and control would be up to you, modern units are microcomputer controlled and the internals are proprietary to the manufacturer typically. Hint- they use thyristors in three triac or six SCR's subassemblies with the heat sink and temperature sensor integrated.
I have one old Wood's drive built before microcomputers, and it has six IC's ST logo 94J535 339. I have no datasheet or control schematic, the drive manual doesn't even discuss which output waveform they are using to approximate, you are on your own. For drive theory the best reference I have found is an obsolete text surplussed by the local community college, "Industrial Electronics Third Edition" by James T. Humphries and Leslie P. Sheets, Delmar Publishers Inc.Albany Ny ISBN 0-8273-3828-7. Enjoy learning!
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500
Last edited by indianajo; 30th March 2010 at 03:06 PM. Reason: input versus output, discuss IC's
Old 30th March 2010, 03:17 PM   #3
star882 is offline star882  United States
star882's Avatar
Use that circuit to convert the AC to about 200v DC, then use a full bridge or forward converter to step it down to the voltage you want.
If you have a high voltage battery on the B+ rails, you can even use the generator as a motor to start the engine and provide additional torque. You can stop the engine at every red light and restart it when needed to save fuel. That's exactly how Honda's IMA system works.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 30th March 2010, 03:24 PM   #4
indianajo's Avatar
Default Additional salvage opportunities
I might point out the the 6 diode assembly from a motor drive is a "three phase bridge". While is is possible to directly convert the resulting 400 VDC (or 200 from 200 3 phase) to 12 DC by switching, you will save a lot of energy by using a switching converter toroid transformer circuit like a PC switching power supply. In fact, one component of a PC switching power supply is a +-12 VDC convertor. The PC power supply rectifies and upconverts the 120 single phase to feed their output converter toroid transformers and FET's. Your mission, should you chose to accept it, is find a way to replace the input part of a dead PC power supply with this three phase circuit, and repair or reuse the output torroid part that produces the +-12 VDC. You might have to rewind a torroid a little bit. Whole lot easier than starting from scratch. Have fun.
Old 30th March 2010, 06:24 PM   #5
sss's Avatar
yes , i want the rectifier to be bidirectional , so i can also turn the magneto with the battery power .of course , some high power step up converter needed.
another question , if i will do that , will the magneto be able to turn with 3 phase square wave signals ? converting the dc to full sine wave 3 phase is much more complicated .
Old 30th March 2010, 06:27 PM   #6
sss's Avatar
yep , i wont need the 6 diodes , as it will cause the full ac voltage converted to dc on the output.the output cannot be higher then 14.7V , so scrs or mosfets only will be used .
Old 30th March 2010, 06:29 PM   #7
sss's Avatar
i need the system to be low weight. adding full bridge rectifier + switching + toroid is not such a good idea.
Old 30th March 2010, 06:35 PM   #8
event horizon's Avatar
Sorry to inform you, but every Mosfet i have ever come accross has a built in body diode to protect the Mosfet itself. The only way round the problem is to incorporate something like a schottky barrier diode in the drain of the Mosfet - that way you'll eliminate any chance of the Mosfet body diode conducting
E2A:- What exactly are you trying to do here? Are you attempting to increase the output of a motorcycle alternator? Just asking as it's something i thought about previously & looking at your avatar..... Well, you know
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Old 30th March 2010, 06:56 PM   #9
sss,
The circuit you posted is a form of a 3 phase boost converter. You can only increase the output voltage, so 15 volts is impossible. Also, the diodes are needed; they act like free wheeling diodes or catch diodes.
Rick
Old 30th March 2010, 07:04 PM   #10
sss's Avatar
Originally Posted by sawreyrw View Post
sss,
Rick
its just a pic i found on the net , dont mind it
we can offer power module of DC/DC Converter & AC/DC Adapter auling Vendor's Bazaar 0 12th May 2009 03:48 AM
DC-AC converter circuit ThSpeakerDude88 Car Audio 33 13th September 2008 04:46 PM
12 DC to 220v AC converter redhorseaudio Power Supplies 1 5th November 2005 04:53 PM
AC to DC converter with selectable voltages? Audiophilenoob Power Supplies 28 11th October 2005 04:51 PM
AC to DC converter with selectable voltages? Audiophilenoob Multi-Way 0 9th October 2005 01:33 AM
Page generated in 0.13155 seconds (79.38% PHP - 20.62% MySQL) with 11 queries
