My project is slowly coming togeather.
It's a modular DAC build. DAC -> LDR attenuator -> Circlotron tube buffer I'll be needing 7-15VAC, 22-24VDC, 6.3V and (2x) +/- 200VDC. The (2x) AN-1T150 will be enough to give me the +/- 200VDC in a floating psu. The other secondaries will give med some 6.3V which will take care of the heaters. All in all I'll have 3x6.3VAC left after powering the buffer. Do you have any creative solutions for attaining 7-15VAC and 22-24VDC? Perhaps I could connect two 6.3V secondaries in series for 12.6VAC? Maybe build a voltage tripler for 26,5VDC and then regulate it to 22-24V? What do you think? Transformers need to be shielded, take up a lot of space and are costly. I'm looking for alternatives to adding more trafos? |
#2 |
Well 12.6vAC will give you close to 17vDC , so with a Doubler you can get over 30vdc that can be regulated to 24v DC , Remember you need to use a lot more capacitance for filtering in a Voltage doubler supply , over double the capacitance ......
Cheers |
#3 |
Actually I see I made a small typo.
I think it should be quadrupler not tripler. Minion> I need both 7-15VAC and 22-24VDC. Playing around with numbers I thank heaven for the low voltage application. 25V caps are fairly cheap even if they are large. (10000uF) |
#4 |
You said you could make 12.6v AC right ?? Isn"t that between 7-15v AC ?? You can use the same 12.6vAC supply for the 7-15v AC and the 24vDC with the Voltage doubler .....
#5 |
Hmm, I never thought of that. I kind of assumed every psu should have it's own secondary on the trafo.
Following the same logic one could connect the 3 6.3V secondaries in series and get 18.9VAC, rectify it and have roughly 26.5V? |
#6 |
Hi, I don"t see why not , I have used a single winding to get several voltages before , have even used the 12.6v AC heater tap through a Voltage Tripler to power the Plate of a Tube (starved plate) and the heaters , have used the Unregulated Power for a Poweramp and regulated it down for the Opamps .... as long as there is enough current to power all circuits and there are no ground loops there shouldn"t be a problem ....
Cheers |
| Need help with voltage doubler | Lingwendil | Power Supplies | 6 | 22nd April 2009 12:15 AM |
| Voltage Doubler | jwatts | Tubes / Valves | 3 | 2nd January 2009 12:13 AM |
| Voltage doubler/tripler circuits | diablo | Power Supplies | 6 | 4th October 2005 04:43 AM |
| voltage-tripler diode values?? | rockstudio | Power Supplies | 4 | 17th June 2005 05:58 AM |
| Voltage doubler | Baard | Solid State | 28 | 17th January 2005 04:46 AM |
| Page generated in 0.09825 seconds (75.37% PHP - 24.63% MySQL) with 10 queries |
