Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th March 2010, 08:02 PM   #1
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Default CAPS ! One big or 4 small ?
Hello Gents ,
which do you prefer , large caps or multi-small caps ?
regards,
Old 26th March 2010, 08:16 PM   #2
Steve Dunlap's Avatar
It depends to some extent on the room you have for the caps. If room is not an issue, then I prefer multiple small caps.
Old 26th March 2010, 08:39 PM   #3
Account Disabled
Default Caps
Multiple Caps, Are better
Old 26th March 2010, 08:40 PM   #4
I would have to agree with Steve, with a caveat. If you have the room for larger caps, then you have room for multiple smaller ones, and vice versa. The advantage with smaller caps I can think of:
1) Lower possible inductance
2) Lower possible ESR
3) Better High Freq. filtering (see above)
4) you can potentially use a lower profile enclosure for the whole shebang.
Peace,
Dave
Old 26th March 2010, 08:58 PM   #5
a.wayne's Avatar
thanks guys , consensus is for multi-caps ....
Old 28th March 2010, 03:02 AM   #6
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Smaller caps have more surface area = more cooling capacity. I use a hundred 0.1uF's in parallel for my induction heater tank cap -- it's the only way to handle 200A with off the shelf components. Big SMPS may need a few caps in parallel for filtering if the switching draws big current pulses (e.g., huge flyback supply), when ripple current can be fairly high. Check the datasheet: in most cases, you can get away with just a few units, even for the most punishing of circuits.
If the question includes line frequency filters, *never* worry about them: there isn't an electrolytic in the world that isn't rated for line frequency filtering. It's just too easy.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 28th March 2010, 05:46 AM   #7
theAnonymous1's Avatar
Another vote for multiple small caps.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 30th March 2010, 04:22 AM   #8
Sch3mat1c's Avatar
Well, as long as we're posting pictures...
Old 31st March 2010, 12:46 AM   #9
Show off!
So what's the assembly with the copper piping for? Liquid cooling, high current, or a waveguide?
Peace,
Dave
Old 31st March 2010, 02:57 AM   #10
Sch3mat1c's Avatar
High current AND liquid cooling. It has to carry 460 amperes (reactive) at full ratings. 20uF 630VDC (250VAC), delivers maximum rated VARs at 10-20kHz (250VAC * 460A = lots of VARs).
I think it would suffice as a bypass cap for something of Pass' design.
Tim
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
2 small subs or one big sub??? chris661 Subwoofers 1 5th March 2009 07:48 PM
Paralleling small value caps with large value PS caps xyrium Power Supplies 16 14th October 2005 04:06 PM
Small trannie and big caps DeonC Solid State 2 4th March 2004 01:50 AM
FILM Caps to assist Big ELYT Caps gromanswe Parts 0 9th July 2002 08:16 AM
Page generated in 0.11148 seconds (77.14% PHP - 22.86% MySQL) with 11 queries
