Need SMPS circuit for LM3886 based audio amp
Old 24th March 2010, 03:54 PM   #1
pradeeppk is offline pradeeppk  India
Unhappy Need SMPS circuit for LM3886 based audio amp
Thanks in advance.
I need a suitable smps for my LM3886(x2) based audio amplifier. I'm new to smps I can't find any smps circuit that suits. please anybody help..
Old 25th March 2010, 03:45 PM   #2
anybody please suggest is that possible to use smps for lm3886 based amp
if yes please give me a schematic , link or any idea..
Old 25th March 2010, 06:15 PM   #3
luka is offline luka  Slovenia
luka's Avatar
I have used it with my own... nothing speacial, like one would use normal trafo
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 25th March 2010, 10:36 PM   #4
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
a search would eventually turn up this link:
Switchmode Power Supply For Car Audio
some useful info but not quite a complete design ....
mlloyd1
Old 27th March 2010, 02:13 AM   #5
is this smps is suitable for my project..?
it is 50-0-50v, how can i modify this to 35-0-35v..?
Old 31st March 2010, 03:49 PM   #6
Anybody please help... how can i modify the above smps in to 35v-0-35v
(is that possible to change feed back zener diode ratings to reduce the output voltage...?)
Is this smps suitable for audio amps..?
Old 1st April 2010, 12:56 AM   #7
ChrisA is offline ChrisA  United States
I can't read the schematic, it's blurry with small text. But look like a couple zeniers down at the bottn used as a voltage reference. Change their value as required.
Old 2nd April 2010, 04:50 PM   #8
Here is the schematic in pdf format.
what about changing secondary winding to change voltage to 32-0-32v ...?
if i have changed what will happen to output current..?
is there any modification need for control section..?
anybody pls HELP...
Old 2nd April 2010, 08:09 PM   #9
stoc005 is offline stoc005  United States
stoc005's Avatar
The each secondary has 9 turns. Needs to be reduced to 8 or 7 turns. The zeners in the opto circuit have to be reduced to ??. YGM. But, I've seen this PS schematic before in power supply forum. Perhaps the designer can help you out. Other than that, it may work.
Personally, I'd buy Meanwell SMPS off Ebay.
connexelectronic.com has a 1KW in a kit form and a 350-450W smps for 50 USD. See if they might do the job as well. Yes, you can save money by buying a blank PCB and chasing all the parts, winding the transformer(s) but it takes a bunch of time and work.
Good luck.
BTW, what's wrong with a 50/60Hz transformer supply??
Old 3rd April 2010, 10:02 AM   #10
joaquim is offline joaquim  Sweden
joaquim's Avatar
I can understand why you wanna use a switch-mode pwr-supply if u have "space" issue or you're to cheap to by a linear solution. I've build a surround system with LM3886, just 'cuz they are well-designed and very few external parts is needed. So the Amp becomes very compact, I've also use the same IC in active speakers. Using SMPS with audio is not recommended, though you will get ripples how well designed SMPS you'll use. Those who builds class-D amp's, knows that converting the pulses into clean sinus is almost impossible, SMPS are o the march, especially in hi-watt PA-systems, were the sound quality isn't the deciding factor, you want people to hear you, and if it sounds good is just a bonus . It's not like leaning back in your favorite chair or sofa and put on Gary Moore, on vinyl...
So why you want to "distort" a good audio-ic with a smps is beyond me... LM3886 is a B-Amp, so you have a quite high efficiency - 85% - 90% - so you wanna use a transformer listed for 150VA, and 25A rectifier and two 10mF(or one 22mF)/channel, and maybe two three 0R15/10W resistors in parallel, in +V and -V, to further suppress eventual ripples, like;
----C(10mF) --- R (0R075)----C(10mF)---> + 35V(-35V)
as simple as they come... But if you up for a challenge and loooong nights, go ahead w/ your SMPS(U).... I'd never use SMPSU in a audio application, RF, pulses, digital designs etc. then they make life easier, but try to build a 20W rms A-amp with a switch-mode supply..... I, like my 'guru' John L Hood(who sadly died a few years ago) am very fond of the class-A amplifier, you have none of the drawback that B, D, T etc has, the major drawback though is the low efficiency, only 20 - 25%, so you'll need 100W of power to get 20W from the amplifier, but you don't have to consider the phase, and you can achieve a well-sounding amp with very few components.... but opinions are like 'behinds'; everybody has one....
Need SMPS circuit for LM3886 based audio ampHide this!Advertise here!
STK4392 based 5.1 Amp circuit suds Solid State 21 14th July 2017 08:52 PM
Car audio LM3886 + SMPS on single sided board rwaudio Chip Amps 43 20th February 2015 02:12 PM
CA 340A SE LM3886 based amp - Upgrade advice please. mikesnowdon Chip Amps 623 27th November 2009 03:35 AM
LM3886 based Amp -Upgrade advice please. mikesnowdon Chip Amps 3 26th October 2008 12:53 PM
LM3886 based amp- questions Atilla Chip Amps 12 6th August 2008 04:55 AM
Copyright ©1999-2017 diyAudio
