I have this kit from qkits, and have a few questions before I power it up, it says its a split rail supply, does this mean reading for each rail +/- needs to be taken from +/- to ground? a reading from + to - would just be the combination of both rails? is this correct? on the PCB you hook up the lead for the center tap next to where it shows ground after the caps.
#2 |
just another
That's correct
The caps will retain charge for a LONG time without some way of discharging and if you short them you could damage them, as well as the possibility of getting a nasty fright or a burn. Tony. |
#3 |
I have been using an old lamp with a 60 watt bulb to discharge caps, I just cut the lamp cord and touch the leads to the output of supply/caps, is this ok to do? it drains the caps and seems to work well.
#4 |
Did it Himself
Yes that's a very nice way.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 |
ok, thanks too both of you for your help, I will power up the supply and make sure it measures correctly.
#6 |
ok, I just looked at the supply and had another question, lol
when measuring the + and - rails to ground, I assume I measure with the positive probe on the positive rail and negative probe on the ground? and for the negative rail do I place the positive probe on the ground the the negative probe on the negative rail? |
#7 |
Did it Himself
Yes. If you connect the probes the wrong way you won't hurt anything, just read opposite polarity (assuming a digital meter).
#8 |
alright, thanks again
#9 |
just another
Hi it will depend on your multimeter! If you have a digital multimeter then you can use the COM (-ve) probe on the ground and the reading will be + or - on the DMM display for +ve and -ve rails.
If you have an analog meter (ie old type with a needle), then you would have to do as you have asked. Light bulb is the way I discharge PS caps that don't have bleeder resistors in them Tony. |
#10 |
the supply tests fine, now I have yet another question, is there anyway to hook this supply up to 2 mono amp boards that both need + and - dc input? the combined voltage of + to - is almost twice the voltage the amp can take, and half would be perfect, soo....
If I understand correctly the negative marked rail gets its positive from the ground, would I just wire the positive of the left channel with the negative of the right channel, then attached them both to the ground on the supply board? or would this result in fire. If that is not clear I could produce a workable drawing of what I mean in MSpaint. |
| power supply question | thetube0a3 | Chip Amps | 3 | 30th January 2010 01:51 PM |
| Power Supply Question | Captn Dave | Tubes / Valves | 14 | 3rd October 2008 07:20 PM |
| Power supply question | woody | Everything Else | 1 | 7th July 2008 04:10 AM |
| power supply question | odysseybmx414 | Chip Amps | 12 | 24th February 2005 06:24 PM |
| Pwer Supply Question | rafalc | Tubes / Valves | 2 | 1st October 2003 11:24 PM |
| Page generated in 0.12271 seconds (76.59% PHP - 23.41% MySQL) with 11 queries |
