Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th March 2010, 03:56 AM   #1
Default Make Amp PSU From Salvaged Parts
I want to make a PSU for a car sub amp to use on a home sub from parts salvaged from second hand store stuff.
I don't want to use PSUs from PCs I want to use a transformer as I am lead to beleive that it's better.
I vaguely know what I am doing but I can follow a schematic and I have completed a year electronics & PC repair course in 1987. I can completely wire a house or a car and build a PC.
So far I know that the amp requires 14.4 volts, have two 30amp fuses, outputs 400watts rms. I checked the specs in the back of the owners manual but no other input specs.
Where can I find a schematic for a project like that? How do I determine the output specifications of the amp? I know I can use the 14.4v but I know that I need at lease on more spec. can I use the 60amps from the combined fuses or can I use the 400watts output?
I don't want to spend a lot on a new plate amp because I have other hardware wants that gets more drool from me but if I can make this quality Alpine car D sub amp work for me cheaply, cool. I already have a 2.21cu. in. 250 watt amp sub woofer
Old 17th March 2010, 08:06 AM   #2
wwenze is offline wwenze  Singapore
The 14.4V input from the car alternator is stepped up to higher voltages by the built-in power supply inside the amplifier, most likely switch-mode.
i.e. I would just give it a power supply with enough amperes and rather modify the built-in power supply instead, if you're looking for better/cleaner power.
If it uses 30 amp fuses 14.4V x 30A x 2 = 864W before the fuse blows 400W RMS output power is probably quite truthful.
Old 17th March 2010, 12:24 PM   #3
I am not looking to modify the amp in anyway as i plan on putting it in my next car I want to make a power supply that plugs into a 120 outlet and connect to the amp as I connect power from the alternator.
salvaged plate amp - can I use here? Dave R Solid State 0 12th September 2009 06:45 PM
Can i use 2 of these PSU to make +- 24V? neutron7 Parts 16 24th April 2009 01:23 PM
Bass amp from salvaged parts? LastInLine Solid State 16 30th May 2007 03:25 AM
salvaged velodyne spl-1200 amp ginsner Subwoofers 1 8th August 2006 10:44 PM
Page generated in 0.07315 seconds (73.02% PHP - 26.98% MySQL) with 10 queries
