Hi all,
I'm designing a power supply pcb (single layer) for a 150W class AB amplifier. The rectifier is off board. I'm using 5 4700uf 63V caps per rail and a 100nF bypass cap. I'd like to ask if the drawing is fine or is something I should change. I put the o fuses after the caps but I see in some psu's the fuses located before the rectifier. Where should they go for optimal protection? The eagle drawing is attached. Thanks!
Kind Regards, Paulo. |
#2 |
Fuses should go before the rectifier in case the rectifier goes.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
| Problems designing an PSU for an gainclone. | samsagaz | Chip Amps | 23 | 30th August 2007 02:20 AM |
| 2xPearl pcb + 2xpearlpsu pcb + parts for psu for sale. | lykkedk | Swap Meet | 2 | 8th May 2007 01:30 PM |
| Help, new PSU blowing fuses | TDWesty | Chip Amps | 14 | 4th March 2007 07:29 PM |
| Help needed PSU designing | k1jroth | Power Supplies | 13 | 6th May 2005 08:21 PM |
| Why does my PSU KEEP blowing fuses?! | Rarkov | Parts | 29 | 17th October 2002 03:35 AM |
| Page generated in 0.06405 seconds (64.22% PHP - 35.78% MySQL) with 11 queries |
