What to look for in a transformer design? As you have probably guessed I am starting off down this DIY road so I have a fair bit to learn
Transformers are a new area to me and I need to understand these a little better before I commit some cash on a pair for my new power amp project. So what would make the ideal feature set for a pair of high quality dual mono 300wpc power amp transformers? I have seen potted designs, electrostatic screens, GOSS bands, encapsulated, which of these are important within an audio environment? What s CT? Seen this mentioned and couldn't work this one out ![]() How do I convert the secondary winding voltage? i.e. if a voltage of +/- 60v is needed for the amp module, how do I know that a 40-0-40 is correct? I have been told this is the right voltage which is great but in future how do I work this out? Any other questions you think I should of asked here but haven't got confused by yet? Thanks, Andy
Source: ASRock with XBMC, SkyHD, Teac VRDS 10 modified DAC, SB3 Proc/Amps: Proceed AVP2, Musical Fidelity AS100, Rotel RB985 Speakers: Monitor Audio GR20, GR LCR, B&W DS3, REL STIII sub Displays: Pana plasma, Sanyo Z1 proj Misc: Isotek Sub G2 & Elite cables |
#2 |
Andy, there is much to explain about a power transformer. Your best bet is to start reading as much as you can and look for detailed projects which include the psu schematic and explanation.
That being said, CT stands for center-tap. It means the second winding has a tap roughly in the middle. You'd be able to measure about the same AC voltage between the middle wire and any of the other secondary winding wires. It'd probably be best if you build a well known and specified design first. |
#3 |
Many thanks for your reply, I have learnt something today
| More transformers | Zero Cool | Swap Meet | 5 | 6th June 2010 07:23 PM |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| Various transformers | Clutz | Tubes / Valves | 4 | 16th April 2006 03:48 AM |
| Back to Back transformers as Isolation transformers | mikee55 | Chip Amps | 2 | 17th March 2006 11:38 AM |
| transformers | Joe912 | Chip Amps | 8 | 3rd April 2004 01:34 PM |
| Page generated in 0.08225 seconds (71.51% PHP - 28.49% MySQL) with 10 queries |
