diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   LC Audio low noise DC power supply (http://www.diyaudio.com/forums/power-supplies/163113-lc-audio-low-noise-dc-power-supply.html)
VT67 13th March 2010 02:52 PM
I was wondering if this would be a good alternative to replace the wall-wart of a Squeezebox Duet. Anybody here who has some experience with this power supply.
L C Audio Technology / Low-noise Regulator
Beepbeep57 13th March 2010 03:27 PM
Hello!
First post here!
I've built this power supply for an active filter: big noise at négative output rail! And with +/- 15Vac in, the poor NE 5532 will die quickly with no load: select +/-24V OPAmp like OPA2604.
Didier
Th3 uN1Qu3 14th March 2010 10:22 AM
It looks a little complicated to me. I'd just go with the good old LM317 and LM337. There was a document around with a study on optimum capacitors for those regulators, but i don't remember where it was (i'm sure people here know it though). If no one else remembers it i'll look around for it.
Erlend Sćterdal 16th March 2010 07:50 PM
Originally Posted by Th3 uN1Qu3 (http://www.diyaudio.com/forums/showthread.php?p=2118501#post2118501)
Yes LM 317 / 337 are old but not good. ;) Discret regulation sounds 10 times better. :)
peranders 16th March 2010 08:00 PM
Originally Posted by Beepbeep57 (http://www.diyaudio.com/forums/showthread.php?p=2117742#post2117742)
Hello!
First post here!
Didier
Did you built it properly? I have a hard time to believe that the NE5532 would die if you had a proper supply voltage. I can see the low margin though.
davidsrsb 17th March 2010 03:32 PM
No filtering on the op-amp power lines. High frequency noise on the mains will go straight through this
I hope that the trimmer is not microphonic
Beepbeep57 17th March 2010 06:01 PM
Hi peranders.
I naturally think of having realized the assembly correctly! Concerning the NE5532, it supports at most + /-22V, thus with 15Vac, we are close to his maximal voltage, where from the risk of strain.
Copyright ©1999-2017 diyAudio
