diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   Schematics help, what component is this? (http://www.diyaudio.com/forums/power-supplies/162479-schematics-help-what-component.html)
hyperion007 3rd March 2010 12:13 PM
1 Attachment(s)
I am planning on building this power supply but there is one component that I don't have a clue as to what it is. I think it might be a zener diode but I'm not sure, and I don't have a clue as to what it's value should be.
I have marked it in red and would really appreciate your inputs on this.
/Daniel
east electronics 3rd March 2010 01:00 PM
its a zener diode
hyperion007 3rd March 2010 01:45 PM
Great! But then there was the question of what values these zener diodes should be?
hyperion007 3rd March 2010 02:17 PM
I found out that they are LM326-5.0 Voltage reference or LM329DZ/6.9V
gfiandy 4th March 2010 09:43 PM
Of those two I would think the 6.9V option would work better. As the amp is set up with a gain of 2 +/- the trim adjustment. 6.9 x 2 = 13.8 so you would need to trim the gain up only a small amount to reach 15V. If you use a 5V ref then the gain needs to be three which I think is outside the range of the circuit.
Andrew
hyperion007 5th March 2010 03:49 AM
Thanks gfiandy! As you might have noticed, I am quite new to this. If you don't mind, I'm assuming that the trimming I need to be doing is only at the VR1 and VR2 to get the desired 15V output. As it happens, I did get the 6.9V options :) Thanks again Andrew!
gfiandy 5th March 2010 04:35 PM
Yes the trim I was refering to is that of the variable resistors VR1 and 2.
Best of luck with your build.
Andrew
hyperion007 5th March 2010 07:34 PM
Thanks a lot Andrew!
Copyright 1999-2017 diyAudio
