My Micromega Stage 6 has developed a continuous buzzing sound/noise in the transformer (inside the blue plastic casing). The noise is quite irritating and prevents me from enjoying music. Else, everything is functioning fine.
I would appreciate any help on how I can get rid of the problem/where I can find a replacement transformer? Perhaps someone has a non-working micromega stage player which would like to dump and can make me available the transformer! would appreciate your help jawa lallchand UK |
#2 |
So here it is again The encapsulated transformers MM used had a bit of a reputation for being noisy. Harmonics on the mains and a slight DC offset are a common cause... particularly if it seems worse at some times of day. This explains it, Mains DC and Transformers might be worth trying the trick mentioned there (AC coupling it) As to modding the player... well I have never worked on a Stage 6 but I would look at the usuals such as opamps (5534 ?) particularly if that's used as the I/V convertor. I found the OPA604 a good replacement, but beware if any opamps make use of the offset null pins as not all opamps are the same in that case.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
| Micromega Stage 2 Mod | dejanm | Digital Source | 9 | 17th September 2007 10:14 AM |
| Micromega Stage 3 problem | wac38 | Digital Source | 3 | 18th January 2007 07:22 PM |
| Micromega Stage 2 (1?) | ManUtd | Digital Source | 10 | 5th March 2006 07:22 PM |
| Micromega Stage 3 CD Player | SPWONG | Parts | 0 | 19th November 2003 06:37 AM |
| Page generated in 0.07168 seconds (65.67% PHP - 34.33% MySQL) with 10 queries |
