I found this circuit while doing some research to figure out a bunch of unmarked toroid cores. Thought I would pass it on.
More turns = less current but higher voltage. The resistor in series with the pri,ary limits current and will need to be chosen for the core size.
Finding new ways for the extreme mis-application of high tech! Last edited by gearheaddruid; 1st March 2010 at 01:33 AM. |
#2 |
That should be CURVE. This can be done at all frequencies using a generator and power amp.
Finding new ways for the extreme mis-application of high tech! |
#3 |
EDN mag has had a number of DIY BH Tracer articles -- EDN PDF
and a thread on DIYAUDIO: B-H Curve Tracer |
#4 |
For circuit values (A_L, Phi_max) I just hook up an inductor to a MOSFET, drive it with my function generator and measure current.
As the circuit suggests, Phi is the integral of EMF (EMF detected with a secondary, so you don't get error from the primary's DCR), and MMF is just the applied current. A single transistor method, as I use, assumes constant EMF (when DCR is negligible), and reads I directly. It allows I = 0, but not B = 0, so a core with high remenance will give silly results (a mag amp core shows up as fractional uH/t^2, highly nonlinear, while a small-signal AC test gives a realistic and consistent value of several uH/t^2). Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
| B-H Curve Tracer | gpapag | Equipment & Tools | 9 | 16th January 2011 08:22 PM |
| BH Curve & OPT choices | Richard Ellis | Tubes / Valves | 5 | 21st February 2010 12:47 AM |
| Tube Tracer | jackinnj | Tubes / Valves | 11 | 20th March 2006 01:10 PM |
| Characterize your core with BH Analyzer | jackinnj | Power Supplies | 0 | 13th January 2006 08:10 PM |
| BH 5 damping | kyrill | Multi-Way | 11 | 22nd June 2004 06:28 AM |
| Page generated in 0.08165 seconds (72.61% PHP - 27.39% MySQL) with 11 queries |
