#11 |
Actually,
Just to see what it looked like, I made the first section after the rectifier an RC instead of a C. This way, the first thing after the rectifier was a resistor. So, I placed a so called soft start resistor right on the rail. Then when you cange the resistor value, you can see how long it takes for the caps to reach steady state voltage for various resistances. It would be nice to do this with a resistor on the transformer primary and also on the secondary (before the rectifier) -- And even better with various thermistors. Thanks, Steve |
#12 |
Another interesting thing that I saw on Duncan's program is:
As I stated in my first post, I'll be using a CLC supply (with a 2.5mH choke). With no soft-start, there is approximately a 54 amp surge of current through the choke on start-up. That is huge. Of course, I have a 7.5 ohm resistor as the load for this power supply. The atual amp will provide a more complex load. So obviously this 54 amps is not accurate. But, I don't know how off it is. However, by placing a 5 ohm resistor on the rail after the rectifier you drop the surge current from 54 amps to 3 amps. Of course when you bypass the resistor, you will incurr another surge. But, I assume it will be less violent. Anyway -- just an interesting observation. Thanks, Steve |
#13 |
use CCS as load
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#14 | |
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#15 |
think inrush
#16 |
don't put Power Thermistors in parallel. The one that heats up quicker, then tries to pass most of the current, leaving the other one cool and high resistance.
Select a higher current capacity Thermistor and use them in series. |
#17 |
I have measured the AVX version of CL-60, it is capable of short term overload of 4 times the rated current.
Magura
#18 | |
If you take a closer look at the datasheets of thermistors, you will find that if you need 10R at 25C, they don't come much bigger than 5A, unless you are willing to pay through your nose. Magura
#19 |
Epcos/Siemens B57464-S0100M
10R, 8A, 6.7W (25C)
Not so much,.......if it says "ZM" in the corner. |
#20 |
For a man with a pair of 3.6KV toroidal transformers that put 80 volts across caps what do you (anyone) suggets?
| Soft start for class AB | VMat | Solid State | 14 | 13th June 2011 09:04 PM |
| Need a soft start current source | woody | Everything Else | 4 | 22nd March 2007 04:38 AM |
| Auto soft-start for class-T amp not working | Nuuk | Class D | 23 | 20th June 2006 07:12 AM |
| variable Low-Cut, High-Pass & High-Cuts | TobWen | Solid State | 3 | 14th September 2004 09:40 PM |
| Choke-Input: How do I calculate the right snubber for high-current-low-voltage | Blitz | Solid State | 20 | 24th March 2004 08:37 PM |
