Help on 2400W Phase Shift PSU
Old 26th May 2010, 04:11 PM   #31
mag is offline mag  Switzerland
Hi All,
I think I solved my problem.
I had a wrong estimation of the primary mosfets Coss so that the shim inductance was too high.
Now I have reduced my shim inductance to 2.5uH (it was 10uH) and everything is fine.
With some work on RC and RCD snubbers my peak voltage on the output
mosfetss is clamped at around 90V with acceptable ringing. The power
dissipation in every RCD clamp resistor is around 2.5W which is something I can manage without problem with 2 parallel 3W resistors.
With the reduction of the shim inductance the A-B leg of the H-bridge will enter in ZVS at an higher output current: at around 40A out the A-B leg enters ZVS and the C-D leg enters ZVS at around 10A.
Even when it works in hard switching the efficiency does not suffer too much: it remains above 92.5% from 20A output and above.
"Do you have pics of the layout? "
Attached you will find the secondary side layout. It is a 4 layers pcb.
All the snubber components are not mounted on the pcb but mounted flying on the back side triying to keep the connections as short as possible
ciao
-marco
Old 3rd July 2011, 06:50 PM   #32
cristix is offline cristix  Italy
Hi ,
I tried to do an boost converter 300W , from 25-40V to 400Vdc .
Can you suggest me some topology ?
Cristix
Old 1st May 2017, 04:02 PM   #33
kees52 is offline kees52  Netherlands
I did see this
I am busy with a fase shift welding inverter for MIG, this needs to be a voltage feedbacked one, a constant voltage source.
I ask myself there are different topologies and I did see that for welding she use the quasi resonant types with a UC1865 controller who do have a VCO and not a normal pcm as in the fase shift version. I read however that fase shift get used more, these do work better? or maybe someone on this thread do now what is the best way.
For the supply who I want to use for the hybrid amplifiers what do put put 65 + 65 v 20 amps 300 volts 300 mA, and 15 volts 5 amps, resonant type with the UC3865 because the transformer sees then a sinusoidal signal who is more friendly for capacitors, and I have soft switching, for welding this is also used.
Thanks for advise,
PS can I use a toiroidal transformer like this one?. keeps radiation small.
https://www.google.nl/url?sa=t&rct=j...hMLiQw&cad=rja
regards
Help on 2400W Phase Shift PSUHide this!Advertise here!
Phase Shift PWM Andrew Eckhardt Class D 6 14th November 2010 07:56 AM
Why am I getting a positive phase shift sigpl Solid State 22 29th December 2009 04:31 PM
phase shift of second order filter bondo Multi-Way 9 8th April 2009 02:24 AM
Zero phase-shift gareth Solid State 11 9th May 2008 04:45 PM
Creating positive phase shift? Pabo Class D 31 14th January 2005 06:44 AM
