I would like to build a High voltage lab supply (60-600V, 250mA) using mosfets as the series regulator.
A current limitor should also be present (so it doesnt explode if it ever gets shorted). Designing such a device is one thing, but making it fool-proof is another. That's why I ask here, does anybody have a schematic of a compareable supply ? (but tested, and approved)
Real tubes have top-caps |
#2 |
I would initialy reccomend using an adjustable of the shelf convertor,
http://www.ultravolt.com/uv_docs/BiPoleCDS.pdf If you are going to build your own then you need to look at creepage and clearance for any PCB, exposed metal connectors etc. Calculating Creepage and Clearance Early Avoids http://www.reo.co.uk/files/safety_7_..._directive.pdf Creepage and clearance distances |
| Is this a practical HV supply? | keantoken | Power Supplies | 16 | 26th May 2009 11:48 PM |
| Switch contacts for HV supply | ThSpeakerDude88 | Tubes / Valves | 4 | 30th March 2008 03:50 AM |
| HV supply please comment before building | bembel | Tubes / Valves | 8 | 5th December 2006 10:16 AM |
| Help with HV DC Power Supply | furly | Planars & Exotics | 3 | 2nd February 2006 12:04 PM |
| FS: Fluke HV Lab power supply | TerryKing | Swap Meet | 0 | 28th April 2004 12:03 PM |
| Page generated in 0.07537 seconds (72.04% PHP - 27.96% MySQL) with 10 queries |
