Hello good people, here is a question for you all
I'm going to be building a few very low voltage but high current class A power amplifiers. Now these are going to be split rail @ about +3.7V & -3.7V with regards to ground. The thing is with a quiescent current of up to 10.5A the ripple voltage on the capacitors i happen to have will be pretty big. I reckon that i should have enough BHC Aerovox 15,000uf 10V caps to give me 45,000uf per rail, so 6 caps total - 3 from ground to the + rail & the same from ground to the - rail. However this isn't enough to give me the ripple voltage i want. So, what would happen if i all of a sudden place a 120,000uf accross from the + to - rail? This would certainly give me more than enough capacitance to get the low ripple voltage i need, but will it work or are there going to be any odd side effects? Please assume that any rectifiers i use will cope with the current pulses, i just need to know what this will do (having never contemplated this previously). Thanks in advance Mark.
"Never let your morals prevent you from doing what is right!" Salvor Hardin |
#2 |
Did it Himself
It will reduce ripple, but you will not be able to draw any current from it as it's connected common mode and your load is differential mode.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Electrons are yellow and more is better!
Excuse me but +- 3.7 V? What sort of load did you have mind? I'll suspect that you have got the class A thing wrong.
If you want to use a 8 ohms speaker the power will be (3.7*3.7)/16 = 0,856 W only!
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
Did it Himself
Hint P-A... 10A quiescent current. More like 0.5 ohm load I'd guess.
#5 | |
A push pull class A output stage driven by a class B or AB similar to a certain technics design. The actual output will be about 250W RMS into 8 ohms & 500W into 4 ohms. Allowing for a 3 ohm impedance you'll find you need 10.5A quiescent current I'm sorry if i didn't make things clear, however i could have been driving a ribbon By the way, cheers richie00boy
#6 |
Did it Himself
OK good luck with the project, but I do believe the class-a driving class-b idea is fundamentally flawed and will only ever give class-b results.
#8 | |
However, i have listened to a few of my own of both push pull & single ended variety. Likewise with what you'd call a proper class A amp with the full rail voltage accross the output transistors with 100W RMS per channel @ 8 ohms. I'm not trying to save the earth but seeing as i get the same quality but by using less electricity (& therefore paying a smaller bill) as well as being able to run it in the summer Besides, there are going to be 6 of them - so every little helps
#9 |
+/- 38V with a balanced amplifier, or if you like a bridge
Another reason to keep the dissipation low, now that makes 12 Class A output stages
| Huge AC ripple voltage - Help Please! | johnmax | Power Supplies | 5 | 2nd February 2008 10:54 AM |
| How to determine ripple voltage? | beerman | Power Supplies | 4 | 21st February 2007 07:27 PM |
| Optimal ripple voltage on b+ supply | nhuwar | Tubes / Valves | 14 | 1st February 2007 05:01 PM |
| Aleph ripple voltage | Pumuckel | Pass Labs | 11 | 10th November 2003 10:06 AM |
| How low should PSU ripple voltage be in a preamp? | DrewP | Tubes / Valves | 5 | 6th February 2003 07:43 PM |
| Page generated in 0.12092 seconds (81.58% PHP - 18.42% MySQL) with 10 queries |
