I have recently started work on PFC for several projects. The main one being a large Tesla coil. PFC involves a special type of boost SMPS to appear to the incoming power as a purely resistive load. It draws current throughout the sine wave not just at the peaks.
I have one circuit handling 4kw constant with a 400 volt output. This will then become the input to a large full bridge inverter. Most modern "universal input" power supplies use this topology. If people are interested, I have a large supply of 1kw power supplies from the telecom world that are all in good working order just missing the heatsinks. This board is a wealth of parts for people experimenting with smps. It has three different control chips and a bunch of gate drive and current sensing transformers on it. There are also five IRFP460 mosfets and numerous high speed diodes. The main transformer is an EC70 3c85 material. I cut the pfc section off of one and with some slight mods, it was putting out 1550 watts with a 120 volt input. If interested, I will sell them for $10 US each. Buyer to pay the shipping. A group buy for overseas would be great, I will work with you on getting them shipped. I currently have thirty of these in stock. I have a ton more of other supplies with similar parts on them I am going to be selling. I will be posting my progress on the pfc development and schematics as I get a chance to draw them up.
Finding new ways for the extreme mis-application of high tech! |
#2 |
A bit of load testing on the large pfc. Stovetop elements are cheap and reliable for this kind of work. Just be careful of the fire thing. (No, not the voice of experience)
#3 |
damn, this is a big unit, since I have 1kw+ unit, and its about 1/5 or smaller... and I don't wan't to compare it to yours... I guess this is 120/230v or is it true "universal input"?
Your design right? |
#4 |
PFC is often a waste of money for US residential users since US residential users are usually not billed by power factor. That means you'll be adding more cost and complexity while (usually) reducing efficiency for no gain. (It does, however, make sense for commercial and industrial users.)
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#5 |
Luka, the pictures are of a board with pfc and three outputs. I am selling them for parts. I rescued them from a recycler, managed to talk them into just unbolting the heatsinks rather than hammering them off. The pfc I have built is 3 by 4 by 2 1/2 inches. I will get a picture up shortly.
Star, the point is to be able to draw more power from an outlet without tripping breakers by averaging out the current draw. For Tesla coils, this is very important. For bench power supplies it helps also if you have limited power available.
#6 | |
#7 |
I'm with you, Ian. The issue for residential users is not one of power factor correction, but the lower harmonic content we demand from the already taxed supply voltage. Those PFC circuits just drive the switching frequency up, though, so we may still have to contend with noise whilst we fix our harmonic footprint.
My local utility is running ragged trying to get my voltage distortion below 5%, which is required by IEEE and PSC. Every little bit helps, and PFC supplies are nearly sinusoidal. Personally, I avoid flourescents like the plague. Ugly light and nasty on the power grid. I'll take my power hungry incandescents, thank you very much. |
#8 |
In applications not requiring tight regulation of output voltage, such as audio amplifiers, PFC provides constant output voltage (with some ripple) regardless of input voltage, avoiding a further regulation stage and voltage selection for worldwide operation.
I use to feel like the small child in The Emperor's New Clothes tale |
#9 |
Most modern pfc circuits approach 95% efficiency so they are not too bad energy wise. Two problems with them is they are not isolated from the mains and when there is an over current, the supply will shut down but the catch diode still passes current from the incoming power. If you have a failure post pfc, it will continue to feed current until a fuse (or something else) blows.
I was thinking about winding a transformer on one of the cores and see if I can still get the same throughput with isolation. Any ideas on this Eva?
#10 |
PFC SEPIC? S'pose it's possible, doesn't seem worthwhile though. When your average forward converter fails, it will end up blowing the fuse anyway, it's just going through an extra choke and diode this time. Potentially more to replace, but all the more reason to not make something prone to explosion in the first place.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
| Power Factor Correction - PFC with MC34262 | luka | Power Supplies | 15 | 21st October 2010 06:15 PM |
| Power factor correction | Stefano | Pass Labs | 3 | 12th July 2008 01:58 PM |
| Power Factor correction | daly41k | Pass Labs | 4 | 30th June 2007 11:28 PM |
| Power Factor Correction | Narcisse91 | Power Supplies | 16 | 30th September 2006 04:04 PM |
| Port Correction Factor??? | mathman | Multi-Way | 5 | 17th April 2006 03:53 PM |
| Page generated in 0.11748 seconds (79.69% PHP - 20.31% MySQL) with 11 queries |
