Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th February 2010, 06:03 PM   #1
DarpMalone's Avatar
Default combined 2 transformers for 24v-0-24v
Hi all,
I combined two identical 24v-0 75VA transformers to create the required 24v-0-24v supply for a chip amp... It does work, but is this safe practice? Also, I've currently got a fuse on the main AC feed before it splits to both transformers. Is this correct or should each transformer be on a separate fuse?
Old 10th February 2010, 06:23 PM   #2
paulb is offline paulb  Canada
Should work fine. It sounds like you have the phasing for the transformers correct, otherwise you wouldn't get much voltage out of them in a series connection.
I would fuse them together because you want both off if a fuse blows.
Old 10th February 2010, 07:16 PM   #3
DarpMalone's Avatar
Thanks for your reply, Paul... Am I correct in thinking that I should be using a 7A fuse if I'm feeding (2) 24v 75VA transformers?
Old 11th February 2010, 09:51 AM   #4
I'm no expert but...
If the fuse is on the primary side, then the total (max) current flowing (if maxxed out which it shouldn't be) will be:
total watts = 2 x 75va = 150va
current = 150va / 110v = 1.4amps (where 110v is your mains voltage? )
For the secondary side, then the current in the +/-24v lines would be:
75va / 24v = 3.1amps.
so 7amps is too high for either situation.
Hopefully someone more qualified than me can confirm this.....
Old 11th February 2010, 05:51 PM   #5
DarpMalone's Avatar
Thanks for the guidance, guys!
Old 11th February 2010, 06:26 PM   #6
dodo is offline dodo  Poland
Hi all,
identical doesn't have to = the same , (winding tolerances )
Did you checked voltage level on the smothing caps ( with no load ) on the + and - side , are they identical ??
You should also consider , every transformer is some sort of inductor , so you have to follow the rules regarding placement two inductors near eachother .
Old 11th February 2010, 07:22 PM   #7
DarpMalone's Avatar
Hi dodo
I checked the secondary voltage on both transformers before combining them and they were equal. I'll check for variance on the +/- this evening.
My case is quite small and currently the 2 transformers are physically mounted parallel to one another... From building x-overs, I know that it's good practice to place inductors in perpendicular orientation... I actually hadn't considered transformer placement. I'll reposition one of them.
24V Add-On Question gootee Car Audio 17 1st December 2009 02:20 AM
24V to -24V? edpgc Power Supplies 4 12th December 2007 07:31 AM
is 2x12v same as 24v Nordic Power Supplies 8 21st September 2005 09:56 AM
Page generated in 0.09313 seconds (75.64% PHP - 24.36% MySQL) with 10 queries
