#2 |
without values its hard to tell, I would guess u2 is a comparator with positive feedback to give hysteresis, and R1 would allow a trickle charge current when u1 (presumably a 317 regulator) is turned off or has voltage reduced (again without the values can't tell)
as for pass transistor, why not use the 3 or 5 amp version of the 317? suggest you try simulating this in ltspice
Anthony C Smith MAES MinstSCE -I think rain is wet so who am I to Judge- |
#3 |
It may be that the circuit will not "start" without R1.
A sim will help. |
#4 |
sorry i forgot to include the values..
R1 1 500 Ohm 1/4 W Resistor R2 1 3K 1/4 W Resistor R3 1 1K 1/4 W Resistor R4 1 15 Ohm 1/4 W Resistor R5 1 230 Ohm 1/4 W Resistor R6 1 15K 1/4 W Resistor R7 1 0.2 Ohm 10 W Resistor C1 1 0.1uF 25V Ceramic Capacitor 104 C2 1 1uF 25V Electrolytic Capacitor C3 1 1000pF 25V Ceramic Capacitor 102 D1 1 1N457 Diode Q1 1 2N2905 PNP Transistor U1 1 LM350 Regulator U2 1 LM301A Op Amp Im thiking that this circuit is a smart charger that i can connect my battery at home while im at work without worring to overcharge it. i was just thinking if it is possible to add a pass transistor to provide a lil more current for bigger batteris.. |
#5 |
i dont have a simulator software yet, and i dont even know how to use them, what was simulator software are you using? and were can i get one?
Forgot to tell you guys that im not good in electronics. but i know some basics.. |
#6 |
This is where it comes from-makes it easier to comment if you have the full article in front of you:
Car Battery Charger |
| Battery Charger for 15V Li-ION Battery Pack ??? | Jan Dupont | Parts | 2 | 11th April 2009 02:18 PM |
| R/C battery and charger | jaudio | Power Supplies | 3 | 18th February 2009 07:27 PM |
| Battery Charger | ThSpeakerDude88 | Everything Else | 13 | 6th September 2006 10:40 PM |
| battery charger = difficult | taloyd | Parts | 10 | 1st July 2005 06:33 PM |
| Page generated in 0.08908 seconds (71.89% PHP - 28.11% MySQL) with 10 queries |
