a bit of a quick question.
reading about the beresford dac's it seems that the power supply is one of the major weak points in terms of sound quality. a few years ago i read that battery is a very easy way to get a good clean power supply. so i was thinking if i bought a pair of 12v batteries (one for use the other to be on charge) and hooked the cable connector to it would this be a good simple upgrade to the power to clean up SQ a bit? i have read plusses and minuses for battery use and it seems that bass can suffer? has anybody tried this sort of thing? or is it going to be a suck it and see? Stu. |
#2 |
Sometimes a square peg fits a round hole just fine
if you use a bank of good quality capacitors and even a nice regulator after the batteries the negative effects are minimized. what are you intending to power with it?
#3 |
it's a dac made by a small british company. so no power hungry power amps needed. so battery life may be pretty good.
just needed to know whether it was worth the experiment? |
#4 |
If you replace original PCM.... chip with WM8716 & redesign whole analog section, then it is worth.
| wall wart and basswood | BluesMagoos | Analogue Source | 6 | 9th September 2007 09:54 AM |
| Sonic T wall wart | Smokehouse Bob | Class D | 7 | 6th November 2006 01:47 AM |
| Wall Wart for testing | bal704 | Chip Amps | 6 | 23rd October 2006 01:47 AM |
| best wall wart for t-amp, where? | gychang | Class D | 3 | 2nd October 2006 12:06 PM |
| Another Wall wart question | JCoffey | Chip Amps | 14 | 2nd December 2003 05:54 PM |
| Page generated in 0.07595 seconds (72.08% PHP - 27.92% MySQL) with 10 queries |
