Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th February 2010, 10:56 AM   #1
ttr is offline ttr  Finland
Default What kind of transformers I need?
OK, here comes a dumb question.
I need a transformer(s) for these regulators in the same case:
- LT1085 for TA2024 board
- LM317/337 for op-amp based active filter
I guess I'll use:
1 pcs 60VA 1x12V
1 pcs 15VA 2x12V
Options?
Old 7th February 2010, 06:37 PM   #2
Minion is offline Minion  Canada
Why do you need different Windings of the same Voltage ?? Wouldn"t a 75va 2 x 12 work just as well ??
Old 7th February 2010, 09:09 PM   #3
paulb is offline paulb  Canada
And you can use a much smaller transformer. What DC current will each of your circuits draw?
Old 8th February 2010, 12:37 PM   #4
TA2024 should play along with 2A and I need about 120mA for the op-amps (12 pcs). When using single 2x12V transformer the major current draw would be on the other winding. I guess that's only a psychological issue..
Another kind of hybrid Michael Koster Tubes / Valves 212 7th March 2012 05:07 AM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
Hi there (kind of) ifrythings Introductions 7 28th October 2005 10:43 PM
What kind of amplifier Madmike2 Solid State 7 12th July 2005 08:44 PM
Different kind of sub rjon17469 Subwoofers 7 16th November 2004 08:42 PM
Page generated in 0.07604 seconds (65.81% PHP - 34.19% MySQL) with 10 queries
