Hello,
I have a resistor in my amp, one end which is attached onto the barrier strip where the hot lead from the AC connects to the power transformer. The other end of the resistor is attached to a blank position on the barrier and goes nowhere/no connection points. What is the purpose of this? This is the wire wound resistor: Mills 1.3K Ω +/- 10% MRW-15 Thank You, Joe |
#2 |
1k3 is too high to be a soft start.
regards Andrew T. |
#3 |
Post a picture
If it's not connected at one end it's not used, and manufactures wouldn't "waste" the money of a redundant resistor. Are there any "options" that can be fitted to whatever it is.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#4 |
I'd like to provide a pic but it's not possible atm. Got me thinking though, its a resistor that literally goes to nowhere, but is attached from position 1 (hot) to the unused portion of a 5 position barrier. The other 4 leads from the transformer are all attached to positions 1,2(jumpered together)3,4 (jumpered together). Then maybe the 5th unused position would have been for the purpose of a 240v arrangement for the transformer (it's 120v now). I dunno just guessing at this point but that would seem logical.
But I guess if it isn't going anywhere, I can remove it since its really just in the way of soldering at this point. Last edited by Pure_Brew; 5th February 2010 at 01:04 AM. |
#5 |
just a guess; it might be to supply low power AC to an optional circuit.
#6 |
How about letting us in on the secret? What amp is it?
#7 |
#8 |
I forgot I had taken a picture of this, at these angles awhile back. Maybe this will shed light.
#9 |
I can only suggest as my earlier post that it's used with some "option" or other. Maybe a remote on/off function... relay board etc... dunno
Having a wire run over the top of something that could get hot (the resistor when used) isn't good.
#10 |
That wire goes to the power switch, not my handywork. But hearing that makes me feel better about removing the resistor entirely, since its in the way for re-attachment. (the transformer has been pulled and sent out for service).
| Turning a power resistor into a power amp (sorta) | N-Brock | Chip Amps | 25 | 7th October 2009 05:10 AM |
| Resistor Power Capacity | JMB | Solid State | 10 | 27th March 2008 09:35 PM |
| Resistor power rating for XO? | JC Fardo | Parts | 4 | 16th December 2004 07:52 PM |
| Page generated in 0.09319 seconds (77.61% PHP - 22.39% MySQL) with 11 queries |
