Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th February 2010, 02:39 AM   #1
JozzaG is offline JozzaG  Australia
Default Power supply
i recently bought a transformer, expecting it to be Centre tapped, however when it arrived it was not. the schematic i have retrieved and decided to use for bulding a power amplifier requires it to be centre tapped.
i bought the M2158 from Dick Smith Electronics
Transformer 0-24V @ 3A (M2158) | Dick Smith Online Store
is there a simple way to use this transformer or is it just easier to buy a new toroidal transformer 80VA 18-0-18.
Old 4th February 2010, 02:59 AM   #2
sphinx is offline sphinx  Canada
see Half-Wave Rectifier on this webpage:
Basic Rectifier Circuits
too many projects...not enough time
Old 4th February 2010, 03:04 AM   #3
cheers for that ill look over it.
Old 7th February 2010, 04:51 AM   #4
dangus is offline dangus  Canada
If the core isn't welded, remove it, unwind the secondary (count the turns) and add a centre tap. I've done this a couple of times. Half wave isn't ideal for power amps; ripple is going to be much worse than with a full-wave supply. It's a useful cheat, though, for low power stuff, like a preamp, if it's followed by regulators. Then you can use an AC wall-wart since those are dirt cheap.
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
How do I diy Hi-End filter power supply and power cord? bmpa Parts 6 24th April 2004 12:12 AM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.08816 seconds (71.38% PHP - 28.62% MySQL) with 10 queries
