I would like to know if I could use a LM22678 as a power supply to supply LEDs from a 12 battary. The LEDs are 3 watt each 700ma draw and forward V. is 3.5 to 4 vdc. Seeing that it will supply 5 amps.Could I just ground one leg of the LEDs and then connect each of the other legs of the LEDs to the out put of the LM22678. I never used any of these,I have only use the small 3 leg voltage regulators. I dont know how to make cir. but I can build from the schematic. I want to connect 6 or 7 of these leds together.
Thank you John Would be nice to find a schematic for the above. |
#2 |
LM1084IT-ADJ is a three terminal regulator that'll handle 5A.
Most people use a constant current circuit rather than a constant voltage to drive higher current LEDs. Bryan |
#3 |
Hello batee, Im just looking for a cir. that would run the led,do you know of one.?
It seems that not many people know how to make up this cir. to run like 7 // 3watt leds together. tks John |
#4 |
OK, so if you're set on using the LM22678, the datasheet probably has a sample circuit. The datasheet is located here:
http://www.national.com/ds/LM/LM22678.pdf Put the LEDs in parallel, set the output to 3.8V, and it'll probably work. I haven't used any of the LED driver ICs, but if you're not stuck on one chip, I think they're a better choice. They require a few external components, but the schematic isn't complicated. They allow you to program the current needed and then regulate the voltage accordingly. LM3404 - 1.0A Constant Current Buck Regulator for High Power LED Drivers There are schematics in the datasheet for these ICs. You can also buy power supply modules for a reasonable price: PowerPuck - LED Supply.com Bryan |
#5 | |
Generally, LEDs for lighting are connected in series instead of parallel. There are also LED drivers designed for this application. Although they are usually limited to Current Output Try searching for "LED driver" or "Constant Current Power Controller" Linear Tech has several High Current LED drivers Linear Technology - LT3756/LT3756-1/LT3756-2 - 100VIN, 100VOUT LED Controller |
#6 | |
Well the cir. that I found on the internet works very well. It lets you connect up 3 three watt led in series ,and they are very bright ,here is the link if anyone was looking to do this.
1.5A Constant Current Linear Regulator for LEDs for Tks to all Johnny Quote:
| Split Voltage Switching Power Supply for Power Amp | vectorplane | Swap Meet | 2 | 23rd April 2011 11:48 PM |
| Switching Power supply | allanon77 | Solid State | 31 | 25th June 2010 06:41 AM |
| Switching Power Supply? | Apocarm | Class D | 9 | 2nd March 2006 05:02 PM |
| Switching power supply | Thomas B | Pass Labs | 15 | 9th December 2002 10:28 PM |
| Page generated in 0.10571 seconds (75.47% PHP - 24.53% MySQL) with 10 queries |
