Go Back   Home > Forums > Amplifiers > Power Supplies
Old 31st January 2010, 08:07 AM   #1
Default Xbox 360 PSU
Has anyone powered a car amp off an Xbox 360 PSU before? I cant get the 12v from the PSU and i know its still good..thanks..
Old 31st January 2010, 09:42 AM   #2
wwenze is offline wwenze  Singapore
High-power devices such as this that have a standby mode would have a power-enable pin somewhere to switch the main PSU off to save power when device is in standby. Like computer PSUs.
Indeed it has:
http://dwl.xbox-scene.com/tutorial/X...HandC-V1_4.pdf
Connect the "Power Enable" pin (pin 7) to ground.
Old 31st January 2010, 08:06 PM   #3
ok. thanks..do u know if any capacitor is needed for the power to run smoothly?
Old 31st January 2010, 08:17 PM   #4
and i dnt understand what is wrong bc im am tieing in my PWR_ENB (Blue) to ground but im still not getting any voltagfe other than my stand by(RED 5V)...How exactly do i tie it ground. Series, Parallel or what..
Old 31st January 2010, 11:07 PM   #5
Went to google it further, seems like there is an error in the document - pin 7 is supposed to be fed with -1.5V to 5V instead of being tied to ground to switch on the PSU.
Old 1st February 2010, 04:12 AM   #6
ok thanks..im surpised i missed that in my google search
Old 1st February 2010, 05:32 AM   #7
ok so im getting the 12v now by coneccting the blue wire to the red wire when i go to hook the 12v and ground to the amp the PSU light turns red..not sure why..i think its because its drawin to much current. the ampifier is round 30amps i think...im not sure any help?
Old 1st February 2010, 08:55 AM   #8
That is likely to be the case, some SMPS-es don't like seeing too much capacitance or the initial charge-up will trip the overcurrent protection. Try using all 3 wires? Or a soft-start.
Old 1st February 2010, 05:23 PM   #9
what would you describe as a soft start?
Any assistance in using XBOX 360 PS? joeybutts Chip Amps 5 29th October 2011 03:24 PM
Any assistance in using XBOX 360 PS? joeybutts Power Supplies 1 21st November 2009 10:17 PM
New Xbox 360 game list ? rojertwose Everything Else 1 18th November 2009 06:15 AM
XBOX 360 or PS3 nikgary The Lounge 11 16th November 2009 05:26 PM
Page generated in 0.09562 seconds (82.61% PHP - 17.39% MySQL) with 10 queries
