Making my first amp ever its an IC lm3886
now I am currently doing the power supply a have a 2x25v 250VA torus trafo and I need to make it DC of course Now in the original plans (which are a bit weird) it says to use mur860 but cause my trafo has a bit too many volts I was suggested to use some oder diodes and condensers in parallel to the diodes. I have 2 250v 25A grez bridges so could I use them and what condensers to use? |
#2 |
The MUR860 diodes are ultra fast recovery ones, therefore highly recommended over conventional diodes or bridge rectifiers. If you need to drop only few volts, the best solution will be to use the MUR860 diodes for rectification and following it few conventional diodes in series. Conventional power diodes drop about 0.6 – 0.7 volt each. Choose diodes appropriate for the peak current consumption of your amplifier.
#3 |
Why do you say your transformer has to many volts? A transformer with 2 25V windings will let you have about 33V + and - after the bridge rectifier and filter caps. Isn't that about perfect for the gainclone?
#4 |
well I am new here so I was told it would be a bit too much for the lm3886 but cause I will make the amp with 2 parallel IC for better sound I am not sure now
so cause I alredy bought 4 mur 880 (there just a bit stronger then 860) I will probably make just the +, see how much power it makes and then decide on what to do |
#5 | ||
regards Andrew T. Last edited by AndrewT; 20th January 2010 at 07:30 PM. |
#6 |
made first half and tested it works and I have exactly 35V so will this do for PA100(2x2 lm3886)
#7 |
According to the manufacturer, the supply range is 20V - 94V: LM3886 - High-Performance 68W Audio Power Amplifier with Mute so there's no problem with 35 Volt.
When paralleling ICs, there's no change in supply voltage, only in the supply current. Make sure you know how to parallel ICs, or have a known schematic showing how to do it. |
#8 |
I have an schematic for audio input and as I understand I just do the power supply part like I would with one IC for every IC so just double it
#9 |
With 2 ICs you need the same amount of voltage and double the amount of current than with 1 IC.
| diode bridge - 10000uF cap - diode tube - small cap - HV+ | engels | Tubes / Valves | 5 | 29th January 2008 10:16 PM |
| hybrid power supply: diode bridge into diode tube | engels | Tubes / Valves | 8 | 24th September 2007 09:18 AM |
| Hexfred diode bridge. | tubee | Solid State | 1 | 4th June 2007 07:31 AM |
| diode bridge using trannies | sss | Solid State | 2 | 18th October 2003 07:08 PM |
| Ultrafast Diode bridge substitution | fr0st | Parts | 10 | 16th February 2003 04:00 PM |
| Page generated in 0.10160 seconds (74.69% PHP - 25.31% MySQL) with 10 queries |
