Is there a way to figure out a toroid based on weight or some other non huge load measurement? I have a 4.5 pounder with 22vac out. now antekinc puts it at 150va based on there weight. However the avel from parts express puts it at over 200va based on their weight.
I have gainclone power supply ready to go if i just have to hook up 1 light bulb across it or something else thats simple. How to measure transformer VA? |
#2 |
The simple short answer is no, there is no real way to figure out va of a transformer without information from the manufacturer.
However "in general" audio transformers normally turn out about 100va per kilo. To obtain an accurate answer needs more info from the manufacturer such as the designed operating temperature. However in some respects the use you make of the transformer will have a substantial effect on the va requirement. Please read the paper on power supplies by Nelson Pass in passdiy. For a class AB amp - probably what you are planning - you need to make sure the va rating is at least 3 times the combined output of both channels in watts. That is 50 watt per channel needs 300va. If you are looking at class A amplifiers I would increase the example below to 450va. Don |
| Transformer VA rating | Buzzy | Parts | 11 | 26th June 2008 09:13 AM |
| Transformer VA versus output power VA | nigelwright7557 | Solid State | 8 | 18th May 2008 02:57 PM |
| How to measure transformer VA? | Original Burnedfingers | Everything Else | 19 | 8th January 2007 11:46 AM |
| transformer VA | pjanda1 | Chip Amps | 16 | 20th March 2005 01:11 AM |
| transformer power/weight ratio | george a | Parts | 1 | 19th January 2005 10:39 PM |
| Page generated in 0.07439 seconds (68.88% PHP - 31.12% MySQL) with 10 queries |
