Go Back   Home > Forums > Amplifiers > Power Supplies
Old 18th January 2010, 12:14 PM   #1
zilog is offline zilog  Sweden
Default excessive undershoot, LM2676 voltage mode controller
I have a circuit that uses a LM2676 voltage mode smps chip to generate a 5V logic supply voltage. The problem is that this voltage is most of the time unloaded, or loaded at only 10mA. When a certain part of the circuit goes active, it pulls current in slow pulse-trains of 100mA added, which causes excessive undershoot of this 5V line (the voltage drops ~100mV for 2ms before returning to regulation).
One solution I have found is to increase the minimum load to 100mA by use of resistance, but I cannot afford this constant power drain from both battery and thermal point of view.
Does anyone know of a way of getting rid of this behaviour short of replacing the LM circuit?
Old 19th January 2010, 06:04 AM   #2
what's the value of the input voltage and the inductor ? for such low current requirement the regulator works in discontinuous mode, and you might have to increase the inductor value.
Old 19th January 2010, 10:54 AM   #3
12V in, 5V out, approximately 10-500mA load. The inductor was 33uH, but some calculations showed that I need 41mA min load at 150uH inductor. Empirical testing also shows this to becorrect if I want the inductor never to run dry.
Thanks for hinting me in the right direction.
Old 19th January 2010, 11:17 AM   #4
u mention before that your current draw is zero or 10mA. for this value, the inductor must be much larger than 150uH. considering 50mA, a 1mH inductor is resonable. also, why don't u use some better regulator with much lower quiescent current which will fit better for battery powered applications ?
Old 19th January 2010, 11:35 AM   #5
Measurements show that the problem goes away at 40mA and 150uH. The reason for not redesigning is that a huge stock of PCBs are already produced and populated, and I am called in to help out another person's design. Changing component values in a few places is all that is economically viable.
variable voltage controller jacquesl Power Supplies 63 6th August 2008 03:21 AM
Current Mode Control And Voltage Mode Control jegandren Power Supplies 4 26th February 2008 08:26 AM
will this average current mode controller work? zilog Power Supplies 0 23rd January 2007 09:17 PM
Excessive output voltage from cd player outputs percy Everything Else 2 26th March 2006 10:30 AM
Current Mode vs Voltage Mode G-Daddy Solid State 11 27th March 2002 06:11 PM
Page generated in 0.08494 seconds (76.45% PHP - 23.55% MySQL) with 10 queries
