Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th January 2010, 06:40 PM   #1
weinstro's Avatar
Default SMPS for Audio Q's
A couple of basic questions for using SMPS in hifi audio applications:
- What level of noise do you design for? Absolute, or percentage?
- What switch frequency do you design for? I'd like to go high enough to simplify the filtering, but not so high that I start to need exotic snubbers and run into weird EMI issues.
- How do you test for EMI/RFI emissions? Do you care?
- What level of load regulation do you design for?
- What level of current slew rate do you design for? I'm thinking 0.5A/us might be sufficient
- SMPS like to have a minimum current draw; some suggest 20% of rated. What minimum level of current do you design for?
Application, ultimately, would be an active powered loudspeaker based on LM3886 IC's and electronic crossover, roughly similar to Linkwitz Pluto.
Thanks!
Old 15th January 2010, 01:35 AM   #2
star882 is offline star882  United States
star882's Avatar
Building your own mains power supply from scratch is not for a beginner. If you know how to work with high voltage, I would suggest modifying a PC power supply. It's very easy to modify a half bridge design for 24v or 48v output.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 15th January 2010, 01:38 AM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Depends on purpose. An audio power amp isn't going to care. Microphone amp maybe. Digital circuitry, not really. High bandwidth analog, yes (radio?).
20kHz is the minimum to avoid acoustic issues, and 50kHz is a very comfortable frequency without needing large transformers. 100kHz is fairly typical for offline applications; 200kHz and up tends to generate a lot of dV/dt, which means possible common mode noise issues (or switching loss).
Low voltage DC-DC converters can easily run into the MHz; I made a cute LED driver ("joule thief") which steps up a 1.5V AA cell to 3.6V 50mA to run a few LEDs -- it happens to run at 5MHz. More sophisticated controllers and transistors (often using MOSFETs) have excellent efficiency and minimal size in this frequency range.
You should care, if even just in principle. It's not easy to test without a spectrum analyzer; your best clues with an oscilloscope will be the "shorted" probe test -- is your ground lead picking up RFI that shouldn't be there? Basically make a loop antenna out of your probe and wave it around, look for anything interesting. I once saw a five-cycle wavelet of 80MHz, 100mVp-p coming off a small converter I built! You're supposed to have "nothing" in the VHF range, where it interferes with radio, television and other more important transmissions (e.g., aviation at 110-130MHz).
Whatever I get, which is in the 1% range or better. I recently built a couple-transistor (no controller chip) flyback supply which, thanks to its TL431 error amp, produced an impressively stable 10.2V from 0 to 3A load!
I've never used dI/dt as a design constraint, only to check against parasitic inductances to see if it's going to fry itself. More amps just means "put the transistors closer together".
The last two supplies I built, I added no leakage resistors. One, a forward converter using the TL494, turned on, ramped up, then stopped oscillating -- I thought something had gone wrong, until I realized it had stopped because it was unloaded. Adding a load resistor brought it back online. The error amp cut off at the appropriate voltage, so it was in no danger of producing excessive voltage. The other, its control circuit drew about 20mA, more than enough to account for its idle current.
Poorly designed switching supplies may be prone to this, but I have not built one which is.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 15th January 2010, 03:18 AM   #4
weinstro's Avatar
Thanks, Tim
Here, I'm more concerned with stability when presented with a 60W transient, like a symbol crash, than with the ability to source a bunch of amps.
Old 15th January 2010, 03:23 AM   #5
weinstro's Avatar
One other question on EMI....
My oscilloscope bandwidth is 10 MHz, not 100. Any suggestions for EMI detection? I'm thinking of interference with a clock radio as my detection method, tuned to either AM or FM bands.
Old 15th January 2010, 04:15 PM   #6
Sch3mat1c's Avatar
Preferably you'd have an electronically tunable radio that covers 1-100MHz or more. Then you sweep the tuning back and forth, and view the amplitude (or AGC signal) on the scope. The tricky part is calibrating it, at which point you might as well buy a real spectrum analyzer.
A clock radio only knows AM and FM, missing the SW band, TV VHF, aircraft, etc. Plus, you'll only hear anything if it's stronger than local stations and modulated (which you could do, by adding a signal to the error amp).
10MHz is really too low for switching supplies, you can't see all the detail, especially if you manage to build something with unusually fast risetimes. How would you ever know, right?
Tim
Old 15th January 2010, 06:36 PM   #7
weinstro's Avatar
Hi Tim,
It's slightly better - a Sony shortwave radio with AM, FM, short and long wave reception. Very sensitive. My amplitude adjustment approach would be to simply move the radio farther/closer to the power supply and listen for issues.
Agreed, completely, but it's what I have. I'm shooting for "good enough" rather than something that imitates a battery. That's why I started the post with a query for minimum PSU performance specs for hifi. Always good to have a target in mind...
Thanks!
Old 23rd January 2010, 06:28 PM   #8
weinstro's Avatar
Default Which ATX??
For my project, I'd like to modify an ATX, as this is likely the fastest, most cost effective approach. Output needs are +/- 28 Vdc. I'll also need +/- 15 Vdc, but I can probably derive that from the main supply easily enough. Target load is 3 LM4780 IC's.
I've learned that there are many ATX supplies out there - thousands. But I'm not sure which ones are great to very good vs. junk. I would like one that has:
- A large 120mm or 140mm fan for low noise
- Power > 250W (peak)
- Larger chassis with some room inside
- Low ripple and noise, as this likely means that the supply includes additional filtering components
- Obtainable from eBay for $50, more or less. Used is fine.
Any recommendations? Corsairs look nice....
Should I care if the topology is double forward, half bridge, full bridge, or something else?
Thanks!
Old 2nd June 2010, 01:43 PM   #9
Ar4 is online now Ar4  Latvia
Send a message via Skype™ to Ar4
Hello,
I wanted to modify PC power supply too, so I could drive LM4780. I need +/-35V.
So, weinstro, have you built that supply?
Old 2nd June 2010, 06:42 PM   #10
weinstro's Avatar
Originally Posted by Ar4 View Post
Hello,
Negative. I did figure out that I need ~600 W in order to have the transient response needed for audio. So, I purchased 2 used ATX style supplies, but have not yet reverse engineered them. Maybe two more months.
Rob
audio SMPS startup Pierre Power Supplies 34 31st March 2011 04:31 PM
Upgrading My SMPS For Audio Use dantwomey Power Supplies 0 11th January 2007 12:42 PM
Help on Dual Chamber Reflex box & car audio response Q's please (LONG) beady Car Audio 7 6th August 2004 11:57 AM
Help on Dual Chamber Reflex box & car audio response Q's please (LONG) beady Multi-Way 0 3rd August 2004 10:09 PM
cheap dorm-audio stuff all DIY Q's theChris Multi-Way 7 5th February 2003 03:43 AM
Page generated in 0.12526 seconds (83.59% PHP - 16.41% MySQL) with 10 queries
