Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th January 2010, 02:09 PM   #1
Post Crescendo power supply
I have build the crescendo about 15 years ago, i havent used it very much because the transformer is humming very loud as the amplifier is about 2 min in use. I have used an Amplimo 1200VA ring core transformer.
Has anyone a similar experience, and what to do about it?
Old 11th February 2010, 03:00 PM   #2
Corax is offline Corax  Germany
That sounds like a bad GND wiring scheme. Somewhere you might have a GND-loop which causes this phenomena.
Disconnect all inputs and short them to GND. Is the hum still present/audible? Then it's in your amplifier. Post pictures from inside and make a detailed scheme on how you have wired the GND-cables. Then we might be able to help you.
Update for Elektor Crescendo Power Amplifier 1982 bjornagain Elektor 56 18th April 2012 07:00 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
pcb for Crescendo power amplifier / 2 pair of mosfets Dusk Elektor 1 23rd December 2006 12:08 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.06137 seconds (67.51% PHP - 32.49% MySQL) with 10 queries
