Uber noob here. I can't seem to find a clear answer to what the voltage rating of a cap needs to be for a valve rectified, cap input power supply. I've seen motor run caps labeled 440 VAC, so am I correct in assuming that if the RMS input to the cap is below 440 V then I'm OK?
Thanks for any help. |
#2 |
I’m not sure if this answers your question, but. If you have a 440Vac motor run capacitor the peak voltage across the capacitor will be 440 Vrms * 1.414 = 622 Vdc and could safely be used in a DC power supply where the peak DC + AC is less than 622V.
#3 |
thank you - i believe you did answer my question. it seems that if you look at caps from hobbyist suppliers they reference the peak voltage a cap will tolerate. However, on an apple-to-apples comparison it seems that a motor run cap rated "VAC" can be directly compared to a transformer secondary which is typically specified as VAC.
| 100uF Motor Run Caps | i45one | Tubes / Valves | 34 | 15th November 2009 06:15 PM |
| motor run caps | grahamb | Tubes / Valves | 3 | 17th September 2009 11:14 PM |
| Motor run Caps Question | Fat Daddy | Tubes / Valves | 4 | 3rd May 2008 10:55 PM |
| dual value motor run caps | wicked1 | Tubes / Valves | 4 | 6th February 2008 09:37 PM |
| ESR of motor-run caps? | JoshK | Tubes / Valves | 12 | 14th December 2007 03:17 AM |
| Page generated in 0.06339 seconds (74.48% PHP - 25.52% MySQL) with 10 queries |
