Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th January 2010, 01:34 PM   #1
Bosk is offline Bosk  Australia
Bosk's Avatar
Default Please recommend a power supply
G'day guys,
I need some help finding a quality regulated power supply for a Tripath TA2020 amplifier please. I'm looking for a pre-built module, not a DIY kit or PCB at this stage.
The requirement is 15VDC & 3.5amps, and my budget (not including transformer) is $100.
Many thanks for your assistance.
Old 9th January 2010, 06:30 PM   #2
gootee is offline gootee  United States
Should be available, no problem.
I opened the mouser.com catalog and on the first page I checked I saw 15V/4A for $31.74 USD for qty 1, not including AC input cord. It's an AULT Medical AC adapter, Mouser part number 675-MW174KB1503F01, and has 100-240VAC universal input, and "regulated output with low ripple".
You could also look at mouser.com part numbers 826-DPS54 and 826-DPS54-M, which might be a little better, for around $60USD and $66USD.
And, depending on your size and mounting requirements, among other things, there are many others, such as 709-LPS75-15, 709-S60-15, 709-RS75-15, and 709-RPS60-15 (all around $40 USD qty 1) and even 709-PS65-15 for $24.20 USD qty 1.
And there are many others, there, of both linear and switching types. Almost all of the 15V ones that go to less than about 5 amps are under $100 USD. Sorry, I don't know the exchange rate to AUS$.
Anyway, surely some supplier that is closer to you will have similar or better pricing on similar power supplies.
Tom
Old 10th January 2010, 01:26 AM   #3
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
Send a message via MSN to authlxl
look my smps module,I can satisfy with you for change some parameter
INPUT:AC220V/50Hz OR 60Hz
OUTPUT:+5V/1A,+15V1A,-15V1A ,+15V/5A
DIMENSION:150mm(length)*100mm(width)*40mm(heigth)
only change main transformer parameter.
look for it here
100w preamp power supply design
recommend me a buffer (bi polar supply) adamus Solid State 14 20th February 2009 02:59 PM
Recommend a high power amp bluejay Solid State 4 29th December 2008 02:09 PM
if I have an amp with less 15W of power, what type of speaker would you recommend? jarthel Multi-Way 17 6th July 2007 09:21 AM
Power Sup recommend? Avi28 Class D 1 10th January 2007 04:30 AM
Pls recommend a power amp to build? pengboon Tubes / Valves 39 17th August 2006 04:53 AM
Page generated in 0.06954 seconds (73.35% PHP - 26.65% MySQL) with 10 queries
