Your opinion about this power supply?
Old 8th January 2010, 08:31 AM   #1
Pigy is offline Pigy  Serbia
Question Your opinion about this power supply?
I need your opinion about this power.
This is the typical power but used as a stabilizer instead of the Zener diode voltage integrated circuit or IC 78xx.
What I complain, is that fellow with the forum say that this is not a good combination.
That in such semi transistor much heat?
Menu is not clear just why it was so, is that the 78xx voltage regulator output current is 1A, but did not take the output transistor current as much as it should?
So I put a resistor R in front of the IC to be limited to the current 200mA, if the transistor has strengthened hfe = 20, and the required output current 5A, so it will be no heating.
Other components in the schema are the standard so I wrote the value of these elements, because my interest in the principle of work and whether this could be the circuit to function, and whether this is a better method of voltage regulation from the old ways with the Zener diode and two transistors?
I expect your response!
Old 8th January 2010, 10:43 AM   #2
microsim444 is offline microsim444  Jordan
Account Disabled
Default solution
You should wait EVA to write you a long letter , without real help.
Old 8th January 2010, 11:08 AM   #3
Why without real help,I need help,because i write that.
Cao!
Your opinion about this power supply?Hide this!Advertise here!
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 06:10 PM
35W MOSFET Power Amp - Your Opinion binary Solid State 20 17th November 2006 12:25 PM
Your opinion on this VCCS heater supply please. Bas Horneman Tubes / Valves 3 31st August 2005 10:23 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 02:30 PM
Copyright ©1999-2017 diyAudio
