I have a UCD 400 amp with 800VA torroid +-60V DC. Will Velleman kit K4700 be able to handle this?
#2 |
I don't fully understand your question because the K4700 is for speaker protection only, and is not contolling the trafo you mentioned. The K4700 is connected to the mains and has its own PSU/trafo. The speakers are connected to the relays and the ground wire is also connected to the PCB.
Do you think the K4700 is a soft start module? because it is not. |
#3 |
#4 |
I am sorry. I was only mentioning that to be sure it can handle the power to the speakers. So you say it is fine?
#5 |
The relays can handle up to 10amps. I think that should be plenty.
#6 |
I see... Thank you. I will order one and test it out
#7 |
I am using this velleman speaker protection circuit, it works great, its well designed, I like it
#8 |
Perfect! No use in blowing up the speakers when this is so cheap
#9 |
Did it Himself
They can pass 10A, but they will struggle with 60V DC at several amps to break though - check out their VA breaking capacity. The only alternative is huge relays but that probably requires a new board, beyond your scope I suspect. So try them, got to be better than nothing.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#10 |
that speaker protection circuit will never see +/-60 volts, it cuts speakers off at 1 vold DC on the ouput...so no worries...
I do not understand why would anyone even brought up the power supply voltage of the amplifier into the equation...that completely does not matter! you can connect the DC protection curcuitry even on 400 volt amp, it senses anything above 1 volts and turns off....no more current! Last edited by adason; 7th January 2010 at 07:17 PM. |
| Velleman K4700 | dome406 | Multi-Way | 4 | 24th March 2008 12:14 AM |
| FS: heatsinks, velleman K4700, bosoz PSU, etc | cowanrg | Swap Meet | 6 | 17th January 2007 02:15 PM |
| velleman k4700 speaker protection circuit | cyteen | Solid State | 6 | 27th May 2005 03:16 PM |
| speaker protection velleman k4700 | wuffer | Multi-Way | 2 | 1st March 2005 05:09 PM |
| Velleman K4700 kit problem | supernet | Parts | 2 | 5th November 2004 07:13 PM |
| Page generated in 0.09300 seconds (77.52% PHP - 22.48% MySQL) with 10 queries |
