simple SMPS
simple SMPS
Old 29th August 2012, 08:17 AM   #21
stewin is offline stewin  Kenya
hi ap2 pls post photos of your project.
Old 29th August 2012, 09:02 AM   #22
AP2 is offline AP2  Italy
Banned
Hi, old model with IR21531D.
also other with EE-42H.
regards
Old 29th August 2012, 09:28 AM   #23
Banned
find old photo.
700w quiet low emi and low hf at output.
Old 29th August 2012, 06:12 PM   #24
very impressive really neat work. i am seeing an aux former is it to drive the ir2153 .?
i will build this smps but i will use irfp460 i will post pcb files . thanks ap2 . i am hoping this smps will reach 1.2 kwts.
Old 29th August 2012, 06:48 PM   #25
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
If the SMPS isn't go to a regulated form, the output choke isn't necessary, and then can eliminate it, but adequate secondary transformer secondary.
If you still want tu use it, be careful that both magnetic fields (From positive and negative rails) must add together.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 30th August 2012, 05:30 AM   #26
eem2am is offline eem2am
Banned
AP2.....we spoke before.....you said you would do coupled output inductors.....but in your above pic i see two separate output inductors?
Old 30th August 2012, 10:31 AM   #27
Banned
I think, that "ignorance" is luck for some company
This i use are pi hf filter,output have very low hf spurius.
it's not a integrator as regulated pwm supply need eg. as toroidal output.
this old smps play on fixed pwm.
Old 30th August 2012, 05:51 PM   #28
Banned
Thanks AP2, but if those arent separate output inductors lying horizontally at the output side of the board, then where are the output inductors?....and if its a LLC converter and doesnt have output inductors.....then what are those two inductors......they are power inductors...they are not ferrite bead type inductors.
Also, when its doing 700W, whats the ripple current in the input electrolytics?.......and what are the mains harmonic currents?
Old 1st September 2012, 02:39 PM   #29
Banned
Maybe help someone, zip contain small exe for turn/voltage of trafo for this smps or similar.
unzip and change extension to .exe
Old 1st September 2012, 02:42 PM   #30
Banned
1-set Main ac voltage
2- set turn on primary (it show frequency)
3- turn's of sec.
it show voltage output (include 100mA load). absolute precise.
simple SMPSHide this!Advertise here!
Simple TL594/single MOSFET offline SMPS EWorkshop1708 Power Supplies 11 25th August 2010 12:30 PM
really simple smps design? oldroborg Class D 10 30th August 2008 10:30 PM
Simple 12V SMPS for small powered devices EWorkshop1708 Power Supplies 16 13th April 2008 10:46 PM
Simple 12v Smps johnyp Power Supplies 13 10th July 2006 01:45 PM
simple smps east electronics Power Supplies 2 12th March 2006 04:21 PM
