Go Back   Home > Forums > Amplifiers > Power Supplies
Old 6th January 2010, 02:52 PM   #1
opor is offline opor  Thailand
Question SMPS need more power
I need 1.2Kw SMPS .And this schematic is interesting .So how to modify this schematic to get more power?
Old 6th January 2010, 03:13 PM   #2
go to 90 kHz and make sure everything stays cool
Old 6th January 2010, 11:21 PM   #3
how?
Old 7th January 2010, 12:20 AM   #4
The values at rt and ct set the osc frequency. Drop some turns on the transformer, You'll probably have to change the current limit circuit values. Put a bigger mains fuse in, put your goggles on, and get ready with the fire extinguisher.
Old 7th January 2010, 12:37 AM   #5
star882 is offline star882  United States
star882's Avatar
Build two of those power supplies with a shared feedback circuit.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 7th January 2010, 12:57 AM   #6
If you built two you could just configure them as isolated single ended supplies.
Old 7th January 2010, 02:01 AM   #7
star882's Avatar
That would cause unequal load sharing if one rail is loaded more than the other.
If you built two that are run in parallel, you could stagger the clocks by 90 degrees and double the effective operating frequency without changing the actual operating frequency.
Old 7th January 2010, 08:51 AM   #8
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
with that core, you don't need to go above 50k for that little power, 49 would do it easy, and my 44 already did it...
Old 19th January 2010, 02:56 PM   #9
Luka
If I use ETD49 how many turns I have to do to reach my target?
Old 19th January 2010, 06:30 PM   #10
luka's Avatar
power is not turns dependent
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
hi power smps jamesrnz Power Supplies 174 29th May 2007 03:31 PM
smps power sg3525 for 3000 wats power alimentation MARAVILLASAUDIO Car Audio 2 24th February 2005 06:58 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.08893 seconds (75.35% PHP - 24.65% MySQL) with 11 queries
