Go Back   Home > Forums > Amplifiers > Power Supplies
Old 6th January 2010, 01:28 AM   #1
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Default Single transistor / blocking oscillator supply
The primary is 400uH, wound in two sections. I used a double E core, ungapped, which happened to measure 90nH/T^2 and 160At saturation. These things are regularly used in computer PSUs for essentially the same purpose, a single-transistor standby/controller supply.
Efficiency is fairly low, around 67%, which can be improved by increasing drive and adding what looks like a current limiting transistor. I haven't done this yet.
Slightly earlier version, breadboarded:
This had a smaller transformer, with no particular attention to winding, resulting in particularly high leakage inductance, as can be seen in the collector voltage waveform:
Current waveform (measured across 0.47 ohm emitter resistor):
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Use of a Ribidum Oscillator as refrence oscillator in a DAC Mark A. Gulbrandsen Digital Line Level 18 2nd January 2009 09:57 PM
The ultimate single ended class a transistor transformer?! dave_gerecke Solid State 3 8th March 2008 11:00 AM
Power Supply Design and Blocking ArtG Tubes / Valves 2 16th February 2007 10:17 PM
A single supply, 2 transistor DAC-IV stage. Brian Guralnick Digital Source 26 4th November 2002 06:50 PM
Page generated in 0.06067 seconds (67.78% PHP - 32.22% MySQL) with 10 queries
