safest way to identify primary/secondary?
Old 6th January 2010, 11:06 AM   #11
ashok is offline ashok
ashok's Avatar
Looks like the attached file doesn't work.
Here is another one.
Edit:
I'm having a problem. I can open this attachment from the original file on my hard disk. However after uploading it I can't open the file. After downloading it Word tells me that I need to install some feature to enable it to open the file ! Any reason for this ?
AM
Old 6th January 2010, 04:05 PM   #12
ashok's Avatar
It's time for me to turn in for the night. Since I'm not sure if you will have a problem with the .doc file from the earlier post, I'm attaching a copy as a text file using Notepad. Look at it full screen otherwise the lines could get mixed up.
Cheers.
File Type: txt Transformer results-DIYaudio.txt (689 Bytes, 7 views)
AM
Old 6th January 2010, 04:15 PM   #13
gary h is offline gary h  United States
I get it now,
those are extra 10V taps to add to the 100V primaries. That makes much more sense, and corresponds with their locations coming out of the transformer.
Thanks for your work on my behalf Ashok, I really appreciate it!
Now to construct an amplifier...
gary
Old 6th January 2010, 04:42 PM   #14
By the way,
I was able to open the first file immediately with word. It opened automatically.
Thanks!
Old 6th January 2010, 04:46 PM   #15
always power up the unknown (and even the known ones) through a bulb tester.
I always attach each lead to a separate terminal of an insulated terminal strip. Makes voltage measurement easy and makes all testing safer.
regards Andrew T.
Old 6th January 2010, 04:56 PM   #16
ashok's Avatar
I tried to open the doc file again using my second computer but it still says the file is corrupt. Wonder if it has anything to do with my ISP ? Many PDF files from this forum will not open either !
Yes Andrew , it's safer to test terminals when they are safely connected to a screw terminal. But often the urge to get it done quickly is so strong that.....
.............we do it the dirty way ! Invites blue smoke of course .....at times!
Now I am going to bed. Have a great day to all those who's day has just started and good night to the rest of you .
AM
safest way to identify primary/secondary?Hide this!Advertise here!
dual primary//dual secondary toroid larryg Chip Amps 22 6th September 2006 10:24 PM
cap btween primary and secondary windings? sam9 Power Supplies 8 19th May 2005 07:34 PM
Why a Zobel network across OPT primary or secondary? ray_moth Tubes / Valves 6 4th March 2005 11:26 PM
Using the secondary of a normal transformer as the primary to get a HT supply baggystevo82 Parts 9 3rd April 2004 12:02 AM
secondary voltage vs. primary voltage Stocker Parts 5 11th March 2004 08:41 PM
Copyright ©1999-2017 diyAudio
