Go Back   Home > Forums > Amplifiers > Power Supplies
Old 31st December 2009, 05:17 AM   #1
Send a message via AIM to Spasticteapot
Default SMPS power supplies - are they really usable?
There's a guy on eBay selling surplus Lambda SMPS units that would work rather nicely for my project - they're good for +/-43V @ about 2 amps. Two of these would make for a fairly economical and efficient power supply, but I'm a little nervous about noise. Does anyone here have any experience with these?
Switching Power Supply 200W Dual +/-43V 2A -Audio Amp - eBay (item 170392013205 end time Jan-05-10 21:30:23 PST)
I WANT TO BUY SOME W22EX001s. PM me if you have some for sale!
Old 31st December 2009, 04:59 PM   #2
star882 is offline star882  United States
star882's Avatar
It looks like a good power supply. It should work great.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 1st January 2010, 09:10 PM   #3
gootee is offline gootee  United States
Keep in mind that it's usually a lot easier to filter out an SMPS's switching frequency than it is to filter out 100/120 Hz from a linear power supply.
If you need to, you can add an LC or CLC low-pass filter to each SMPS output, and maybe even follow with a linear post-regulator. You should be able to get the noise down to tens of microvolts.
Old 2nd January 2010, 02:52 AM   #4
godfrey is online now godfrey  South Africa
Gotta love the documentation!
(available here: Hi )
"Just for the record, I, the person providing this information, am a penniless peasant living in the mountains of Nepal."
Quote (regarding the power cable):
"Steal one from an old toaster or other broken appliance."
Quote (regarding shock hazard):
" It can give you a jolt hard enough to cause you to knock other things around on the bench, possibly causing a bigger fiasco."
Old 2nd January 2010, 10:06 AM   #5
AP2 is offline AP2  Italy
Default SMPS for Amplifiers (Audiophile-Performance)
Only one is true dedicate for amplifier.
no EMI-No Ripple is DPS-600, ultra compact, see www.audiopower.it please.
Best Regards
Old 2nd January 2010, 07:30 PM   #6
darkfenriz's Avatar
Looks nice, just a very basic forward converter.
Be carefull with adding any extra capacitance at output, it can become unstable.
to AP2:
please don't treat DIY forum as a free way to advertise what you're selling
Old 2nd January 2010, 08:25 PM   #7
I just thought I would throw in my two cents about these SMPS, I bought 10 of them a while back. Follow the mod sheets they will really help with high voltage regulation and adjust ability as they originally pulled the the adjust off the low voltage side, if you do not need the 3.3 and 5VDC remove them all together along with the analog board as it is not needed with the mods. I also replaced the barrel diodes in the HV side with to220 8amp high speed ones. As for noise they can use a little better filtering, but that is a simple fix better inductors and filters, as for added capacitance they seem to handle 20000MFD alright, no issues and I have had them running for over a year.
All in all if you have some parts in your parts bin and some time these make great little supplies. They will provide a constant 200W into a load as long as you keep them cool.
Old 2nd January 2010, 11:25 PM   #8
Account Disabled
This is good supply, Cant remember who manufacture those, Think they are china models
But it works. get it
Old 3rd January 2010, 03:42 AM   #9
That's a bit worrying, as the application note for the amp basically says "Use REALLY BIG power supply caps". Is this less of a requirement if an SMPS is used?
Old 3rd January 2010, 09:00 AM   #10
(To:darkfenriz)
I only pointed out a product that I consider very interesting. I do not sell! I would love to discuss and confront various circuit techniques, innovative instead of the usual 30 years old. must see .. flayback for audio amplifier? and other PSUs fall under voltage bursts (12-14Volt )?... nice! add capacitors?
I respect the work and passion of others.
SMPS for audio is critical, IMD, THD and noise are not easy to solve and then there's the issue of response time to the current. (Vital sign of a good amplifier) does not seem interested.
could address the problem by sharing the experiences of all of us.
Best Regards
LM4780: Maximum usable power output yusuf Chip Amps 3 2nd April 2007 11:13 PM
What are SMPS supplies?(Feeling ignorant) hernanstafe Power Supplies 2 10th March 2007 03:41 PM
smps supplies traw Vendor's Bazaar 0 31st December 2006 04:57 PM
SMPS-PWM design with bipolar supplies rtarbell Power Supplies 2 27th December 2006 09:48 AM
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 18 31st August 2006 10:39 AM
Page generated in 0.11451 seconds (77.48% PHP - 22.52% MySQL) with 10 queries
