Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd December 2009, 12:18 PM   #1
mark02131's Avatar
Default Duel Rectifier Issue
I am building this power supply that uses 2 5Y3GT rectifiers but noticed that my power supply (a hammond 302AX) 5v is only 3 amp and the 5Y3GT data sheet specifies 2 amp heater current. Is there anyway around this, should change the power supply to only use one larger rectifier? what if I run the heaters in parallel? Here's the schematic
Old 22nd December 2009, 12:39 PM   #2
mark02131's Avatar
I just realized they are wired in series so they are only using a total of 2 amps anyway is that correct?
Old 22nd December 2009, 01:09 PM   #3
Frank Berry's Avatar
The filaments are not wired in series. They're in parallel.
You might try a 5AR4 which can deliver more current with less voltage drop.
Frank
Old 22nd December 2009, 02:01 PM   #4
mark02131's Avatar
Your right they are parallel I would like to use the duel tubes if possible, maybe I could get a second 5v transformer to drive them or something.
converting tube rectifier to solid state rectifier. tubo Tubes / Valves 26 24th December 2009 12:12 AM
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
duel op amp power supply assymetry tolerance mazurek Parts 2 12th February 2006 05:13 PM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
Page generated in 0.07439 seconds (74.83% PHP - 25.17% MySQL) with 10 queries
