I'm working on my first project, so this is a very nooby question but I want to be sure I understand.
I have a center positive wall wart which I need to reterminate. The positive wire is marked, so I can easily cut the old terminal off and resolder the new one on. What is the best way to test it? I know I can plug it in and measure the current with my multimeter, but how do I test to make sure I have center positive? (This is somewhat theoretical, because I can be pretty darn sure to solder the positive wire in the center, but I want to understand what I'm doing.) |
#2 |
Uhm, what is there to understand?
If you have a DC wall-wart you can just switch the wires, or if you like to do it complicated, you can cut the wire, use the ohm or beeper mode on the multimeter(asuming it has one) and find the center-pin wire, then mesure where the positive lead is and connect the dots from there. Unless I misunderstood you of course. Just try not to electrocute yourself(irony, I doubt it's even possible unless you really get creative |
#3 | |
Best regards Ebbe |
#4 |
#5 |
You mention that you have a multimeter. Did you notice what colour the probes are? One is positive (red) and the other is negative (black). If you connect the red probe to the positive and the black probe to the negative, you will get a positive reading.
This is SO basic. Seriously. |
#6 |
If you're going to be working with electronics, perhaps a refresher course in electricity is in order.
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#7 |
diyAudio Administrator
When you can write a whole page essay about how electron flow is taught back to front at school, this is hardly a stupid question. http://www.eskimo.com/~billb/amateur/elecdir.html - should you connect a multimeter black to red, or black to black? If you've never done it before, how would you know? Shudder to think you might politely ask on a forum instead of crossing your fingers and hoping for the best and having enough money to buy it all again if you screw it up.
Matt welcome to the forum, and my sincere apologies - we have some people here that forget what it was like to first pick up a soldering iron with a sense of wonder and curiosity. If we can't make newbies feel welcome here there is a serious problem - this forum was set up specifically to help newcomers bridge the gap between want and have. |
#8 | |
Banned
I guess if you look at it that way, however what he asked wasn't even related to audio, this is diyaudio right ? ANYWAYS! it's a simple thing to do, its just as easy to unplug a cord from the wall and flip it over and plug it back in, you match wire for wire, using your meter to check polarity after, and bing its done. |
#9 |
Hi Jason. Matt said he's working on his first project. Yes, could be a motorized alligator project. Probably is an audio project. But it doesn't matter anyway. I think the point is that it's best to never assume and be as friendly as possible to people sticking their neck out to ask what to most of the members here are simple questions though
#10 |
Matt I apologize for being a bit snide. Like Jason says, we forget about our own humble beginnings sometimes.
Have fun. |
| wall wart and basswood | BluesMagoos | Analogue Source | 6 | 9th September 2007 09:54 AM |
| Wall Wart for testing | bal704 | Chip Amps | 6 | 23rd October 2006 01:47 AM |
| best wall wart for t-amp, where? | gychang | Class D | 3 | 2nd October 2006 12:06 PM |
| 2 Wall Wart PS Question | Sherman | Chip Amps | 13 | 22nd February 2005 09:25 PM |
| Another Wall wart question | JCoffey | Chip Amps | 14 | 2nd December 2003 05:54 PM |
| Page generated in 0.12019 seconds (79.64% PHP - 20.36% MySQL) with 10 queries |
